Question about John Deere Garden
Deck does not engage when pto is engaged on x534 ?
  • 1111 Answers
SOURCE: G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Posted on Aug 07, 2009
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 4 Answers
SOURCE: PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Posted on Aug 20, 2009
A PTO that is engaged constantly,
On that type PTO engagement there is slack in the belt that disengages the deck, in some case there is a arm with a idler pulley that swings against the belt to tighten it and engages the deck , in other cases like older MTD:s the deck swung backwards as it was let down and tightened the belt and was lifted to turn it off. Most of the decks had a brake of some kind on the deck pulleys to stop freewheeling of the blades when disengaged .
May 26, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why can't I engage the mower deck?
Riding Mower Electric PTO Clutch Won't Engage When Hot ...
? 7:16
www.youtube.com/watch?v=wH9tZl6GzE0
May 2, 2014 - Uploaded by Steve O The PTO is relatively easy to change assuming that you can get the bolt out of the crankshaft. Basically follow ...
Sep 09, 2015 | Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Where do i attach the PTO deck engagement spring on the cutting deck of the 2009 cub cadet LTX 1040 PTO deck engagement cable attachment on the cutting deck
Wherever it was that you took it off from. If it broke, then look to see where a spring might be while you have a friend slowly engage and disengage the assembly. If it's an electric engagement situation, bring it to a shop. If you don't have a friend, sorry. I'll be your friend.
Sep 25, 2014 | Garden
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Sep 01, 2014 | Garden
Pto not engaging in john deere lx 167
Check the voltage on the wire(s) connector to the PTO switch. Sometime portion of the switch can go bad. If you have voltage coming in to the switch check the output voltage going to the clutch..
Apr 03, 2012 | Garden
John Deere 160 Mower Deck Switch - mower deck does not engage when switch is turned on. The "dead man" engine shutoff still functions when the switch is engaged - if the switch is on and there is...
Hi, check that you have 12 volts to the pto when the switch is on. It sounds like your pto is fried as the switch is functioning correctly. Regards Phil.
Sep 20, 2011 | John Deere Garden
DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Apr 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
170 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
