Question about Kingston Data Express DE110, S21P104 Removable USB Drive Enclosure, Frame Only (074061707886) Drive Case
Reg Removable disk
Hi !
I'm praveen can you pls reply for the below,
How to protect my removable pen drive from others access, how to protect it so that only I can access & use the removable disks can you reply to my mail- praveenthetrainer@yahoo.co.in
  • Kingston Master
  • 27,725 Answers
Click start click on computer to open you should your drives
C: usually your hard drive D: or E: your cd/dvd drives if you have 2 and your usb drive possibly E:or F:
Click on your usb drive right click in it select new folder option you can name it
Then put all files or data you want to password protect
Right click on the folder select properties then click sharing tab tick in make this folder private box
Another message might appear you do not have a password on this account click yes
User and password account will open for you to put in place a password
This might vary depending on your operating system in XP
Select properties then security tab at learn about access controls at the bottom of the box
Also another option to change permissions click edit
Then click deny then click apply in W7
or
http://download.cnet.com/%7Bvalue=http://www.download.com/usb-safeguard-free/3000-2092_4-75115673.html
USB Safeguard is a portable software program to encrypt and protect data with a password on your removable pen drives using the AES 256 bits encryption.
The main purpose of using a USB pen drive is that you can bring your data with you wherever you go. But if you lose your USB pen drive your data also lose.
This is dangerous if you have confidential files stored in it. Protect the pen drive with a password. USB Safeguard offers users (novice and expert) a friendly yet extremely powerful security solution that fully protects valuable data stored on USB pen drives.
Also, the program has a useful feature that allows you to enter your email or phone if you lose the pen drive. Free version works only with USB Flash drive of size max 2 GB
Posted on Nov 13, 2013
3 Suggested Answers
  • 3 Answers
SOURCE: KINGSTON pen drive is not responding
you might have problem with your driver cd of vista. it is easily availabale in net. Install usb softwate to fix this problem.
check device manager all hardware working correctly or not.right click on my computer then go manage.
if something showing question mark, double click on it.It will be automatically installed
go in run type->gpedit.exe and check hardware function is terminated or not.and make it active
Posted on Jan 21, 2008
softwareguru
  • 78 Answers
SOURCE: pen drive write protected problem
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Posted on Jan 08, 2010
I cnt open my pen drive..it's showing insert disk..it is a cruzer blade 16gb pen drive..and I have a windows XP..
Windows XP should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
May 09, 2012 | SanDisk 8gb X2 = 16gb Cruzer Blade Usb...
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a kingston pen drive which is automatically write protected. i am neither able to formant it nor use it. so pls tell me how to get rid of it?
When you attach the usb drive, after that right click on my computer icon and click Manage option. After that under Manage console select Disk Management, look for removable drives (that is your usb drive) under it and then format it. It will be formatted.
If that also doesn't work, use some special file formatting utilities like Disk Wipe, File Format etc.
After the drive is formatted you ll be able to use your pen drive.
Thanks !!
Please rate the solution if you like it.
Nov 23, 2010 | Computers & Internet
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How can i install abode reader from pendrive to pc, give me tips step by step
if u have the Adobe install file in the pen drive,
access the pen drive thru USB, connect the pen drive to any USB port on ur machine.
once the machine detects the pen drive it will show up on my computer as "Removable Drive/Disk"
double click that and u can access the file sin that pen drive.
if u have the corrcect executable file for the Adobe installer just double click on it and it auto install it on ur machine...
it may ask for the drirectory to be installed and the serial number.
pls provide as requested.
Dec 25, 2009 | Microsoft Windows XP Professional for PC
When is insert my pen drive in compute then show insert a disk in drive
In order to resolve the issue, use the following methods given below:
Method 1: Insert the removable disk in the removable drive before you start your computer. But in this case, make sure that the first boot device in BIOS is not USB drive, else computer may not boot at all.
Method 2:
1. Log in as Administrator account in windows or any other account with administrative privileges
2. Insert your removable disk into the USB port.
3. Click Start, now right click on my computer and select manage
4. Now, click Disk Management
5. Right click on your removable drive partition and select Change Drive Letter and Paths under Disk Management ( you can find your drive easily through size )
6. Change the drive letter some other drive letter like X: or Z: which is not reserved by some other drive on windows.
7. That’s it! Done.
Regards,
Shrey
Oct 07, 2009 | Computers & Internet
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Sep 26, 2007 | Computers & Internet
Kingston Data Express DE110, S21P104 Removable USB Drive Enclosure, Frame Only (074061707886) Drive Case Logo
120 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
