SOURCE: Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
SOURCE: cannot align ink cartridges in my cannon mp160 printer
Normal
0
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: cannon MP210 printer
I tried this and it worked (thanks to a suggestion from someone else but can't find his name right now) --
I found a slender piece of cardboard, the front off one of my 1-subject notebooks. I cut the jagged edges off, made sure there wasn't any debris or loose crumbs of paper. Put about 20 sheets of paper into the printer and put this cardboard as the first sheet. Pressed the copy button. When it started to attempt to feed, I forced it through.
What did it find?? A moth had flown into the printer at some time, gotten smushed, smashed and stuck -- and was preventing the paper from feeding through! OMG, I almost tossed this Canon MP210 in the garbarge.
So thanks to you guys with ideas about cardboard and a little muscle. I ran another piece through just to clean out all the stickiness (and the remnants of the moth's body). Works fine now.
webstuff
SOURCE: Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
CAUTION:
a. Do not try to manually move or stop the Print Head Holder.
b. Do not touch any metal parts.
Note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
Note:
Ink Tank Lamp
You can check the status of each ink tank according to the way its lamp flashes.
Note:
SOURCE: Ran out of color ink on cnnon mx310 ... want to
You can print documents even after the cartridge has run out of color ink except that it cant print color documents properly or cannot print them at all.
It cannot print color documents properly because a color cartridge can have 3 colors if any of these colors is exhausted then it wont print that color at all.
But this wont affect black and gray scale printing.
So nothing to worry.
Good luck.
