Question about Troy Bilt 175HP Manual 42" Riding Mower
How do I take off Front Tire of Power Built 500cc 17.5hp 42 " cutting deck Riding Lawnmower? I have flat tire and want to get repaired. Model # is 13WN77K5011 and Serial # is 1E040B50080
    President:
  • 3,074 Answers
Http://www.ehow.com/how_7479789_change-tire-troybilt-riding-lawnmower.html
Posted on Mar 13, 2011
How do I take a front tire off a craftsman lawn tractor
some have a plastic hub cap that you pry off then either a cotter pin or a c clip that needs to be removed .
Aug 26, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need repair sequence for flat front tire on DLS 3500 Craftmans Riding lawnmower. Actually, just need to remove it and I will take to local tire repair shop for repair.
Go to your local auto parts store, purchase a tire plug kit, leave the tire on the machine, plug the tire per instructions (personnel at the auto store will explain the use of the kit to you) and pump up the tire.
When you are done, put the tire repair kit in your car.
These things are lifesavers, every car should have one.
Once you have done a few flats, you can do them with air still in the tire in about a minute.
Good luck, Gary
Jul 10, 2011 | Garden
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Front tire leaks. How do I remove the wheel for
Pop the hub cap and remove retainer. You could install a new tube yourself if you didn't want to have the tubless tire repaired.
Jul 25, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
The riding mower doesn't cut evenly...one side cuts higher than the other...
The following steps will make any riding mower cut evenly.
1. The rear tires must be the same diameter i.e. same tread type and the same tire pressure (check it before each mowing).
2. Level the deck following the instructions in the manual and recheck it occasionally
3. Make sure the blade(s) are not damaged and kept sharp, rounded blades tear instead of cut.
4. Make sure the deck and its attachment points are not bent or damaged.
5. Drive at a slow walking speed with the engine at cutting speed.
6. Over lap rows in amounts sufficient to lift and cut the tire tracks from the previous pass.
7. Cut the grass at intervals that ensures you never have cut more than 1/3rd the total length of the grass.
8. Make sure the underside of the deck is clean.
9. Use a blade style that matches the type of grass you most often mow.
Jun 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cuts lower on side
first and foremost! make sure the tire pressure is correct in ALL TIRES and then level the deck.
May 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do you remove the front wheel of a Troy Built riding lawnmower to fix a flat tire?
well depending how its fastened on there could be a couple different things to do. but no matter what take a jack and lift up the front. if its a c-ring get c-ring pliers and pull it off. then just slide it off. if it has a hexagon bolt take a socket or wrench take the bolt out and slide off the tire. hope this helps you
May 10, 2010 | Garden
Troy Bilt 175HP Manual 42" Riding Mower Logo
323 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
