I bought the exact matching ac power supply for my MA7 but it still will not powerup! I've never seen the screen lightup the day it was given to me... It is a nice machine and I would like to get it going! Thx-N-Advance
  • 8,404 Answers
You have a nice, broken machine. That is why the price was what it was. Have you checked the battery? Some laptop computers will NOT come on if the battery is dead or faulty. In my experience, if the battery is done for, you might consider purchasing a new machine. Batteries typically run from $85.00 to $150.00, US and a new laptop can be had for slightly more than $300.00.
I understand even $150.00 is less than $300.00. Here is the thing, your computer has never worked. You might spend the $150.00 for a battery and could still have a broken machine - then what - but a new one that your new battery will not fit? What else could be wrong? Spilled soda on the key board shorting out the works. Dead hard drive. No or faulty memory. Faulty or bad display. Cooked processor due to insufficient cooling.
My advice, salvage the parts and replace the computer.
Thank you for your question ! FixYa.com
Posted on Mar 13, 2011
    Sniper:
  • 69 Answers
1. remove the battery and try again,
2. test the power supply on another machine.
3. malfunction on the main board.
    Master:
  • 525 Answers
You might have to replace the motherboard.
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
Need replacement power supply
JBL parts online
ebay seller has this listing
AC Adapter For JBL on stage 400p Speaker Dock iPhone iPod OS400PBLK Power...
the power source specs are on a sticker on the device or online search for its specs
nothing wrong with universal power supplier from an after market power source supplier
Mar 22, 2017 | JBL Audio Players & Recorders
C3200 stuck on error screen
did you check the contact from unit 1 and at the back or a connector rest error,power supply board
Feb 18, 2013 | Canon imageRUNNER C3200 Copier
Push power button it lights up for 3second then shuts off what is wrong with it
Could be bad ac adapter or bad motherboard. Have seen lots of cases where the ac adapter was bad and the laptop no longer starts after the battery goes dead.
Jan 10, 2013 | Gateway M360 M460 M680 MA2 MA3 MA7 CD DVD...
Do you have a contact or website for the manufacturer of the PowerUp TC3J-4050P ATX Mid-Tower cases? I've contacted Tigerdirect.ca for warranty for a dead power supply and they tell me I need to...
there are no web site.tiger and other compamys have other people make up systems at low cost to sale. just like gateway hp emahine you will have to buy a power supply if you see it to work sorry to say that but some of us do not like that companys do that. i build i know that to be true jim
May 15, 2011 | Power Up TC3J-4030 P ATX Mid-Tower Case
If someone has an original Sega Genesis 2 power supply, can you tell me the exact volts, amps and polarity that uses? I know there's a lot of adequate replacements, but I want to use one that matches Sega...
Well I'm happy to say that i have a genesis 2 power supply on me Its specs are
  • Input: 120v AC 50 Hz 15W
  • Output: 10v DC 0.85A
If you don't have the required power supply already or can't find one you can find a replacement here
Feb 11, 2011 | Sega Genesis 2 Console
Gateway ma7 will not power up
Gateway MA7s have dodgy DC sockets. Poor solder joint on +ve pin = increased resistance = lots of heat = burnt PCB around +ve pin usually shorting the +ve pin straight to ground. If you're lucky you might still be at the poor solder joint stage and the DC socket might simply need replacing and/or re-soldering. If not, it could be a burnt PCB and it's a pain to bypass the burnt areas due to how the power gets distributed around the PCB.
Apr 18, 2009 | Computers & Internet
AC adaptor for 32 inch Protron TV
It seems a lot of people are having problems with the Protron power supply. I’ve been able to repair all the ones I’ve seen so I’m confident I can fix them. I don’t sell the replacement power supply but I’ve heard about the ones on EBay. They seem to be a mishmash of two power supplies (12vdc and 24vdc) wired together with the proper connector. This should work but it just doesn’t sound very clean looking to me and they end up costing $150.
I’ve been charging between $50 and $100 to repair these power supplies. My recommendation would be to send me the power supply I’ll check it out and unless it’s unusually damaged it will cost $50 plus shipping to repair. If I can’t repair it I’ll return ship it and only charge for shipping.
I will guarantee the repair for 1 month. I don’t know what’s causing the power supplies to fail so I can’t guarantee it any longer than that. My feeling about the reason the Protron power supply stops working is two part; could be overheating due to lack of proper ventilation to the power supply; or the TVs power requirement is overdriving the power supply.
Feel free to contact me if you have any questions.
I repair these at my work, so here’s the shipping address:
Dave Simpson
23372 South Pointe Dr.
Ste. B
Laguna Hills, CA 92653
Also, I’m set up for PayPal.
dave@thola.com
Sep 10, 2008 | Protron PLTV-32 Television
Start-up
Have the power supply replaced. It is a very simple procedure. I would recommend buying an 80+ model which is very efficient.
May 05, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
