Question about Bausch and Lomb Optics
I bought a used, fixed stage microscope to try and fix it. I have cleaned out the gunk from the ball bearings for the course focus but can't get the tube to raise and lower. Any resources you could link me to, if you can't identify the problem from such a vague description, would be helpful as well.
  • 3,186 Answers
You posted this in the telescope topic.
Posted on Mar 14, 2011
Why does the mechanical stage for my microscope keep falling to the bottom-most position?
Maybe there is some wear at the thread where the stage fits, causing that the stage cannot hold.
Mar 19, 2016 | Nikon Labophot trinocular Microscope...
The stage is not moving when the focussing Knobs are moved. The stage moves freely vertically. It's not attached, I'm sure it needs to be re aligned and a screw need tightening, but which screws?
Hi Faye , we will probably need more info
Does the stage move freely on its own without the course focus knobs
Can you move the stage up and down with either of the course focus knobs
Instrument details / picture would help .
Oct 07, 2015 | Science & Laboratory
My microscope won't focus, i tried everything...i don't know what is wrong with it...it's brand new.. it worked a couple times but now it just stopped.. i dont know what brand it is...all it says is...
If your stage is still in its correct orientation then make sure your objective lenses are screwed in tight as well as the eye piece being secured correctly. Try using different objectives (don't go too high or you may damage your lenses if you ram it into your specimen) and using the fine and course focus. If the you still cant focus using different objectives it's quite possible that your mirrors or lenses inside the microscope have been knocked loose. I would then recommend only having it repaired by a certified microscope technician. If it is still under warranty take it back to the store of purchase or send it back to the manufacturer.
Jan 04, 2010 | Science & Laboratory
My microscope drfits out of focus, how can I fix this?
The problem is that the stage is heavy and the adjustment screws are loose. You need to tighten the coarse adjustment knob screws in order to create more friction so that the stage stays put. That, or don't adjust anything and keep holding on to the coarse adjustment while you're using it.
Nov 19, 2009 | Boreal WW3111900 Microscope
Stage slowly falls causing unfocus
Try holding the Right knob so it does not move, whilst firmly moving the Left knob towards you (clockwise), this is the adjusting method used on Zeiss Jena 1960's High End microscopes, e.g Eduaval & Ergaval.
Good luck,
Alan Mowle
Mar 05, 2009 | Science & Laboratory
Focuser broken
Not really a solution, but anything is better than a posting that get's NO response. It sounds like the rack and pinion drive has collapsed. If you're good with your hands and have a knack for things mechanical maybe you can dissassemble the stage mounting and see how it's meant to work. If something has come loose rather than broken maybe you can fix it. If teeth have stripped from the drive gear - you may be unable to effect a repair. I guess trying to fix it is better than doing nothing. Have a good 2008
kevin
Jan 05, 2008 | Meade 8200 Monocular Microscope
Microscopes
sir,
Diffrent company having their own system for microscope arm balacing.
Tell me which one microscope you have.
Auxillary arm or microscpe body sloly come down ward.
tell me problem is consult with which part..
INDRAVIJAY
Jan 02, 2008 | Tasco 750 Monocular Microscope
Optics Logo
24 people viewed this question
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Piyal Perera
Piyal Perera
Jeffrey
Jeffrey
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
