Question about Dyno Cycling
While changing the rear wheel, the rerailer came off and I dont knoe how to get it back on propertly? Can you send me pictures on what it should look like. I have an model #D2658TR Pacific Cycle (Dyno) Bike.
    Brigadier General:
  • 8,546 Answers
Google: "rear derailleur installation" for many videos
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Posted on Mar 13, 2011
Fuel gauge not working propertly, goes up and down all the time
The fuel pump cage has a guage on it which needs to be cleaned, luckely you dont have to change the pump for this problem. Now its very easy to clean, you will need a pencil with an eraser on the end, with the eraser clean the patanchio meter element and place it back in the tank.
Sep 16, 2011 | 1992 Honda Accord
The pictur freezes to balck and white.
Tv have a colors wheel design into it.Tv make alots of noises like grinding,humming,buzzing or pictures freezes or lost colors or flashes black&white flashes within the pictures.The tv colors wheel it is dying and the colors disc is it warping and not spinning correctly inside it motor walls axis anymore.The tv colors wheel must be replaced.The tv colors wheel sit way back of the tv and have to take out alot mechanical parts out before even can come to it and change it.If u have no mechanical skills.Don't attemp change the tv colors wheel by ur self.Hire a tv tech.person to change it.
Jun 30, 2011 | Samsung HLN617W 61" Rear Projection HDTV
TCS light, ABS light, 4 wheel drive light, come on periodically! What causes this? What is the solution? Thanks in advance
Possibly a wheel bearing is going out, which can cause the speed sensor to lose signal quality. Please see my tip at http://www.fixya.com/cars/r6003525-abs_traction_control_lights . These are genericinstructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
May 05, 2011 | 2004 Hyundai Santa Fe
Hi i have a 2004 hyundai sonata recently my car has been making sort of a vibrating noise and a feeling and i dont knoe what it is and theres no check engine light on please someone help i dont knoe whats...
hi from uk may i suggest that first you do some diy checks ? check all tyres are inflated correctly ? then check all wheels are secure? if your steering wheel is not juddering? then you may not have wheel balance problem? also your problem may be one of the engine mountings have failed ie the mounting rubbers have parted from mounting plates this will cause juddering thro out car especially when taking up drive from standing and also as you accelerate and declerate if you are unsure how to check mounts may i suggest you have tyre depot or garage check and report only! as you can do replace mounts diy ? any more info ? come back if you find out fault if you wish help ? hope this helps/inspires you
Feb 20, 2010 | Hyundai Motor 2004 Sonata
How to replace rear axle bearings 2004 vw jetta
take off rear hub u have a inner and outter bearing ..change bearing dont forget to pack new bearing well with a GAA Bearing Grease...and install wheel and tighten middle nut till wheel is tight...then back it off enough that wheel turn but not too freely about half a turn back....GL
Aug 30, 2009 | 2004 Volkswagen Jetta
I cannot get the rear wheel off the tractor. Question... the ''square key''... I thought mine was missing & secured another one, but WHAT DO I DO WITH THE SQUARE KEY ? Is the original still in the hub part...
Here is what my manual says. It is for a 14 hp 42" mower deck. 6 sped transaxle.
Block up axle securely.
Remove axle cap, retaining ring and washer to allow wheel removal (rear wheel contains a square key. Do not lose).
Repair the tire and reassemble.
On rear wheels only: align grooves in rear wheel hub and axle. Insert square key.
replace washers and snap retaining ring securely in axle groove.
Replace axle cap.
If you send me your email address I can send you a picture as I do not know how to post pictures on here yet.
Apr 24, 2009 | Craftsman Garden
I have the samsung slm phone. The camera on the phone is upside down. How can I change this?
Um try sending it back to the factory
if they will accpte it,
if you got warenty ur in like
just buy a new one
thats all i knoe
Jul 23, 2008 | Samsung Lands Phones
Cycling Logo
114 people viewed this question
Top Dyno Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Dyno Cycling Expert? Answer questions, earn points and help others
