Clothes come out very wet. Niosy clunky none smooth cycle
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
Try following my guidance notes on balance first (PS, you don't say what make OR model but top or bottom load, it's all the same!) --------->
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 13, 2011
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
If this is a vented dryer then check all the filters in the machine also check the vent hose is not blocked on the machine in the hose itself and where the pipe goes out of the wall.If it is a condenser dryer the filters need checking and the condenser box in the base of the machine.If none of this is successful then it could be a fault with the heater or the programmer.
Hope this helped.
May 09, 2010 | Dryers
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Clothes still wet after spin cycle
the first 2 things you need to check is:
  1. if it is spinning as fast as it used to
  • if not it needs a new clutch assembly ($35 + labor)
  1. if it is draining as fast as it used to
  • if not then it needs a new water pump ($30 + labor)
there is no filter that would cause this problem. prices are from repairclinic.com
  • if none of this describes the problem then let me know and i will help you figure it out. i know these machines well.
Mike
Jul 01, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
