Question about Microwave Ovens
Panasonic nn-t775sf microwave oven not getting hot, i measured the two diodes on the inverter power supply one is open and one is shorted anyone have a service manual? or idea part number to replace them
  • Microwave Ovens Master
  • 8,404 Answers
Before you do all of that, please check the door safety interlock switches for proper operation. These switches report to the oven if the door is open or closed. Forget what you know about the door, the oven needs to be told and in the simplest of terms. If you regularly open the door with the oven operating, you have probably damaged the contacts of the tiny switches. If the contacts do not close (open) properly, they don't report the door as being closed and as such, the oven will not turn on the heat (magnetron).
If you find these switches are operating properly, I suggest you check with www.repairclinic.com for your parts or with a FixYa.com advertiser whose message you will find around this page.
Thank you for your interest in FixYa.com
Posted on Mar 13, 2011
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Powergard inverter 1000w nn-cd987w
Fixya does not sell replacement Powergard inverters.
Oct 19, 2016 | Panasonic Microwave Ovens
Why panasonic microwave oven stops working
when it does that is power supply. they do that. change power supply and see what happens
Apr 29, 2014 | Panasonic Nn-sd681s 1 2cuft 1200 Watt...
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Just replaced the magnetron in my Panasonic NN-S543BFR. I still don't get any heat from my oven. Everything works as set but still no heat in oven. Need suggestions on repairs.
When you say "Everything works as set" do you mean the microwave appears to function properly, but then doesn't heat?
If the magnetron is new, then the magnetron must not be receiving the required high voltage (2000V or more) from the HV circuit. Make sure you've got 120V to the PRIMARY (don't attempt to measure secondary voltage of the HV transformer without special equipment) of the HV transformer. After that check the HV capacitor and diodes. If these components test OK, then either your HV transformer is bad or your new magnetron is faulty. My experience is that the problem is usually in control circuitry, preventing 120V to the HV transformer, or opens/shorts in the HV components (diodes and capacitors).
Mar 15, 2010 | Panasonic NN-S543BFW Microwave Oven
Hi, I have a NN-C784MF microwave oven from panasonic which is inverter based. The two diodes # ux-c2b are blown. I replaced them they blew again.Please help. Regards.. Anwar.
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Dec 30, 2008 | Panasonic NN-SN657SMicrowave Oven
Panasonic nn-sn667b 1300w dead
You might consider just replacing the inverter assembly itself.
It will cost more than replacing the bad discrete components of course, but you would be avoiding the time and money involved in parts research, trial and error, and possible destruction of any newly installed parts if there remain other undiscovered defective components.
The inverter assembly (part # F606Y8M00AP) can be had for $79.12 here.
Otherwise, you would need to order the service manual, which is not listed by the major Panasonic distributors.
The service manual should be # SM-NNSN667.
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
In this case, call might be more productive to track down the service manual.
Good luck, and be safe.
Dec 24, 2008 | Panasonic NN-S954WF Microwave Oven
Panasonic Microwave Warm
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
Jan 30, 2008 | Panasonic NN-S960WA Microwave Oven
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
105 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
