Question about Philips Televison & Video
Plilips 17pf994512 Blank screen but sound ok
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Haier l32c300 screen blank sound ok
After checking the cables and connections if it still has a problem, take it to a repair shop.
Apr 03, 2014 | Televison & Video
Compaq Presario V6205NR blank screen when i turn on
connect it to external monitor - if blank to then problem in video card if works fine then check LCD cable - test it with any multimeter with sound mode, iuf OK then carefully connect it back, if broken then replace it, so, last one is LCD, if video card OK , LCD cable ok - then replace LCD
Nov 13, 2012 | Computers & Internet
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Format of my Plilips Flat TV
there is a format button on the remote
Apr 07, 2010 | Philips 50PFP5332D 50 in. Plasma...
BELL HOWELL 17462 PROJECTION SET TV SCREEN WENT BLANK
Do you still have sound? Can you see light at the back of the set when the screen is blank -if so the bulb is ok and you've just lost video.
Oct 14, 2009 | Televison & Video
LE40R74BD VOLUME OK BUT BLANK SCREEN
sounds like the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
both are serious , also could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swolled on top and are easy to solder in cost about $1 EACH
Jul 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Picture comes on for 2 seconds then tuns to black screen Sound ok
Hi!
This more then likely a back light inverter board issue! It can be intermittent or just black an non responsive.
Feb 18, 2009 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
