Question about LG WM-2277HW Front Load Washer
My LG WM2455HW washer turns on by it's self and some times trips the circuit breaker
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be absolutely anything- internal wiring/plugs sockets, control panel switches, control PCB, etc.etc.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 13, 2011
Lg washer wm2455hw door won't lock. DE code flashes.
LG Washer Door or Lid Won't Lock - Model WM2455HW ...
www.repairclinic.com/...Washing-Machine/...-/LG-Washer-door-or-lid-...
LG washer door or lid won't lock? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Nov 15, 2015 | LG Washing Machines
LG Washer WM2277HW wont turn on what can I do?
I would try plugging it into a different self dedicated outlet. It also might be the internal plug connection. Use a heavy duty extension cord to see if it works off a different circuit.
Jan 23, 2012 | LG WM-2277HW Front Load Washer
LG Washer trips dedicated breaker
That to me seems like an electrical problem. Every now and again you can get a bad GFCI receptacle that will constantly keep tripping. I would also see that the GFCI is properly sized for the circuit. It needs to be a 20 AMP circuit (just dedicated to the washer) and a 20AMP GFCI receptacle. The way to tell is the 1 of the three prongs of the 20AMP GFCI will be in the shape of a "T" while a 15 AMP will have 2 straight prongs and the ground prong. Hope this ws helpful, don't go spilling any money into your washer without getting that fixed first, because it doesn't seem like a washer problem.
Apr 30, 2010 | LG WM2016C
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
It powered off by it's self and now i can't get it to turn back on.
Try unplugging the machine, then check to make sure the wall oulet has proper voltage. If not, check your household breaker panel for a tripped breaker, then plug your washer back in and try it. If it's not a breaker (or possibly a fuse or GFCI outlet that's tripped), try spinning the drum quickly by hand to see if it "powers up" momentarily. If it does not, you may have more serious issues. However, unplugging LG washers for up to 24 hours seems to take care of a lot of their problems (for awhile, anyway).
Oct 11, 2009 | LG WM-2277HW Front Load Washer
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
LG S36AHP-UD7 Split Air Con. won't turn on.
Generally when an ac trips the main breaker and the breaker its self isn't bad, the compressor is going bad or is bad. To check you will need to do an ohms test on the compressor. If you get a reading of less than infinite, then the compressor is bad. You will need to test every lead going to the compressor which is usually 3 unless you have a crank house heater installed but they are not typical on a small unit. If the compressor has gone bad it is possible the it took the board out as well.
Mar 31, 2009 | LG Heating & Cooling
Kenmore top load washing maching tripping the breaker
the breaker is likely worn out, have that checked by service person first, then check that machine does not need to be lubed etc. for too high a load on the circuit.
Feb 09, 2009 | Kenmore 15864/15862 Top Load Washer
LG WM-2277HW Front Load Washer Logo
103 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
