Question about Yamaha Audio Players & Recorders
Our 575 's tray opens every time it gets to disc #4.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 92 Answers
It mite be off track
Posted on Mar 16, 2011
How do I fix the xbox360 open disk error I replaced the eye and I still keep getting the error Please help!!!!
I've experienced this problem too. these following steps helped me to solve it: 1: blow air in the xbox while the tray is open to remove dust. 2: put disc in tray and open and close it like 5 times. 3: You probably heard this before, clean the disc;) 4: Maybe sounds weird, knock on the xbox while its reading the disc. Hope this helps u
Sep 21, 2013 | Video Game Consoles & Games
Tip
INITIALIZE THE DVD PLAYER -FIRMWARE UPDATE
FIRMWARE UPDATE
1. Turn the power on and remove the disc on the tray.
2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
The DVD player can also enter the version up mode with the tray open.
3. Load the disc for version up.
4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
5. After programming is finished, the tray opens automatically.
At this time, no button is available.
6. Remove the disc on the tray.
How to Eject Manually
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Jan 19, 2016 | Denon DVD-1740 DVD Player
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
I put the disc in and on my tv it says open tray and when I do that and close it it says reading then goes back to open tray.
Hi friend try this:
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive.
Please vote for me.
Feb 09, 2010 | Microsoft Xbox 360 Console
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 30, 2010 | Teac DV-H500 DVD Player
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Disc Tray
The rubber band inside your PS2 might be broken, the rubber band supports the disc tray and it ejects and inserts the tray.
Sometimes if play too much long, some of the PS2 parts will be damaged by excessive heat, so my advice is that your minimum gameplay time must be 3-4 hours only.
Please den't even try forcing the tray to open, it will be more damaged.
Try resting your PS2 for about 1-2 days, after that try to open the tray, if the problem still persist bring to a PS2 fixer near you.
Jul 29, 2008 | Sony PlayStation 2 (PS2) Console
Disc tray won't open
needs new tray drive belt
Feb 08, 2007 | Philips FWP900 System
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
