Question about Vacuums
I have a Kirby Sentria that no longer has any suction. The head and belt parts are burning hot after only a few moments of being turned on. The bag is empty, the green light is on and everything appears to be working, but it is not sucking at all and is extremely hot! Also, when I ran the vacuum before noticing the issues, the fiber of the carpet were covering the head of the vacuum and piling up all around it. I have no idea what to do!
  • 1462 Answers
SOURCE: no suction in vacuum on a Panasonic MC-V7355
the device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
Posted on May 03, 2007
  • 7 Answers
SOURCE: Kirby sentria
Hi There, The machine does not actually suck the suds up. Basically the machine lays the foam down which then crystalises and absorbs the dirt in the process. Once this has had around - 4-5 hours to dry then you vacuum up as normal taking the crystalised dirt away. You should really use the Genuine Kirby product as it's very good but you can also you any other DRY FOAM shampoo. Hope this helps Chris www.elidistribution.co.uk
Posted on Sep 23, 2007
SOURCE: Kirby Sentria
If the green light is off, then its time to replace the band. This video shows you how.
Posted on Dec 30, 2008
galati2k
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: kirby sentria carpet shampooer
you dont **** out the water....if you use the reccomended Kirby shampoo there is no need to **** out the water because it is a semi dry liquid ...it will dry by its self in about 1 hour....I,ve been with Kirby for 16 years now ...i will know
Posted on May 19, 2009
Kirby sentria 2
Make sure the belt is the right size.. It should be very very tight.
Apr 16, 2014 | Vacuums
Kirby Sentria 2 burning smell (not belt)
Actually it can. If the machine has a defect but the good news is that is has a 3 year warranty. Take it to a Kirby authorized repair shop not a vac and sew and they will fix it right up....I am a factory authorized service tech for the Kirby co.
Dec 16, 2013 | Kirby Generation 3 Bagged Upright Vacuum
On a Kirby sentria the metal spool sticking out that goes into hose or power head becomes extremely hot and left burns marks on brush tube. It only gets hot when using power head. I checked all adjust
Check the brush roll to be sure it's spinning free too much drag can cause that to get hotter but usually it would break the belt. That spindle will get hot from the friction created by turning the belt and from the motor's heat. They'll just get hot, any brand that spindle will be hot after running it. It's just how it is.
Feb 05, 2013 | Kirby Vacuums
No suction from my kirby sentria
I just took a stiff piece of coax cable, and took the bag off where it attaches to the main unit, and took the head off ( the part with the brush roll in it) AMD cleaned every thing really well, turning the spindle for the fan while " snaking" it and pulled out a baby sock! Ta-Da! Works like New.
Apr 29, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I have a kirby sentria. vacuumed up my son's headphones and immediately shut if off. took brush off, unwound headphones, put it back together. when i turned it back on, the belt snapped. so i went to...
Take the front off the vacuum and check inside both the front portion and the canister for additonal clogs. Sometimes something will get caught in the impellor, causing the motor to overheat. Since there's little suction and the smell, I'd guess this is what happened.
Jan 30, 2011 | Kirby Generation 3 Bagged Upright Vacuum
My Kirby Ultimate G does not have enough suction to pick up pet hair. Is there anyway this can be corrected? I felt under the vacuum when it was running, the roller is running, but I felt very little...
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Hi -- I have a Kirby Sentria and it is great except that I am getting no suction at all through the big silver power head. Suction through all the other attachments works well. I haev tried it with the...
You can take off the power head and look in that whole where the belt is and see if there is a paper towel or something in there clogging it up.
Also tug on the belt and make sure it is tight - because if it is loose it is broken and you need a new belt.
While you have the head off, put on your hose attachment and use it to **** out any debris stufk in there.
Dec 08, 2009 | Kirby Vacuums
Kirby sentria
remove the cloth bag from the bottom it twists counter clockwise, un clip the bag from the top remove the head piece, turn the belt lifter clockwise and release the lever to remove the head, take off the head, in your attachments there should be a screen that covers the impeller that the belt rides on it goes on like the brush head, put your hose onto the bag port by turning clockwise. there it is it will not work without the screen cover. thanks Rene
Aug 29, 2009 | Kirby G6 Bagged Upright Vacuum
Hose for G3 Kirby doesn't fit Sentria
Yes G3 and G4 had different gasket thus the suction blower connector connecting Kirby hose to the unit on later models is different. You do not need to replace entire hose but just the plastic part that connects to the vacuum. You can find it HERE. To remove old connector you may have to submerge the end of the hose into hot water (not to hot to touch) so the vinyl becomes soft and you can bend it in with finger bringing plastic end over the lip on the molded end of the hose.
Good Luck
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby sentria
you have to make sure the green light is on.. in the corner .. and if it is that means its working properly. If you have no suction then it is usually the belt and or the bag. so make sure your bag is not full , make sure everything is attatched properly and the green light is on.... The Kirby is the best vac out there and little suction should never be a issue for us.. I am a proud owner of the sentria..Love it..
Jul 05, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
