Question about Montgomery Ward Heating & Cooling
How can I get the specs on a Montgomery Wards Heavy duty 1000 water heater? We are trying to find out how many Amps it draws.
    Guru:
  • 683 Answers
Look on the internet for ohms law. when you find it you can use this formula to figure out what you need.
Posted on Mar 13, 2011
The fuse for a starter located on opel kadett 200is
The starter can draw as much as 1000 amps at initial contact and thereafter 250 to 300 amps while swinging the engine, therefore there is no fuse for the starter. Power is fed directly from the battery to a solenoid which is in reality a very heavy duty switch, and from there directly to the starter field coils and armature. No fuse.
If the starter won't turn check the battery cables, the solenoid and lastly the starter itself.
Jun 23, 2014 | Opel Kadett Cars & Trucks
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
Feb 03, 2013 | Water Heaters
I have a montgomery wards furnace model srm54013a. won't shut off, keeps putting out heat
SOUNDS LIKE A BAD THERMOSTAT OR THE RED & WHITE WIRES IN BACK OF STAT ARE TOUCHING ONE ANOTHER COMPLETING THE CALL FOR HEAT.
Dec 25, 2012 | Heating & Cooling
I have a Rheem Model # 82V52-2 and its being supplied by 25 amp breakers. They do not trip out but the 100 amp main gets real hot and trips out and I believe it happens when the water heater is in use- any...
The Rheem water heater uses 4500 Watt elements
Check label on side of any appliance to see electrical rating details
2 element tank with two 4500 watt elements is still a 4500 watt appliance since both elements are never ON at same time.
Volts x amps = watts
amps = watts divided by volts
amps = 4500 divided by 240Volts or 220Volts
amps = 18.75
Your water heater uses 18.75 amps to 20.45 amps
Your 25 amp breaker should only carry 80% of rated value
25 amps x 80% = 20 amps.
So your water heater breaker is correctly sized.
You should have a 10 gauge wire going to this water heater.
12 gauge wire is a bit undersized for 4500 Watt water heater
Feel the water heater wire to see if it is warm.
If the main breaker is getting hot when 20 additional amps are being used by the water heater.
1) The house is using more amps than your 100 amp main can carry
Using the formula, 100 amps x 80% = 80 amps for the main breaker
Add up your total amp draw.
For example if your 3500 watt oven is ON, it draws 16 amps.
If your 5000 Watt electric heater is on, it draws 23 amps.
Your 1500 Watt 120V microwave draws 12.5 amps.
Add these numbers up plus your water heater, and it comes to 71 amps.
71 amps is getting close to the max 80 amp, but it's not over.
Now if you have a pool pump and and hot tub and a table saw going, the main breaker could be overdrawn.
2) To solve the problem short-term, you can put a timer on the water heater and use it only when needed.
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
3) The main breaker is bad and needs to be replaced.
If you need help figuring circuits or timers, add a comment and I will help
Nov 05, 2010 | Rheem Water Heaters
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
Wick and manual for Montgomery Wards Windsor kerosene heater
Hi, I have a Montgomery Ward Sunheat heater. It's a dual burner enclosed type with a door on the front. The fuel tank is cylindrical and about 1 1/2 - 2 gallons. The cap has a needle valve and when turned upside down releases fuel to the burners by gravity. The whole heater itself is rectangular with louvers on the sides and top. I don't know what wicks go in this or if there are compatible replacements out there.
No 84ALO5800A is the only I.D. or Model No.
Thanks,
Jack
Nov 27, 2008 | Montgomery Ward (223600UP) Heater
Heating & Cooling Logo
93 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Mack Baxter
gbob59
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
