Question about Dell Office Equipment & Supplies
Have a laptop connecting to the internet via netgear WGR614 router. I would like to host my dell 942 connected to my dell demension 3000 so my laptop can print
  • 4,340 Answers
What you need to do on the host computer is SHARE the printer. You may need to reset sharing permissions, and if you have NORTON, you need to turn lots of stuff off, or the printer will never show.
Posted on Mar 13, 2011
Trying to conect laptop to virgin media with netgear wireless adaptor the signal is strong but could not conect windows say to contact provider provider gave me number to enter 192.168.0.1 now i am lost
The router is not connected to the internet via Virgin media.
Your computer is connected only to the router wirelessly, that is why it says contact your internet supplier on how to connect the router successfully!
Jan 12, 2011 | NetGear WGR614 Wireless Router
Laptop shows connected to network via netgear router wirelessly but wont connect to internet
I would recommend checking that your laptop is set up on the access list in the router. Login to the router and check the settings.
May 26, 2010 | NetGear WGR614 54Mbps Wireless Router...
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Netgear WGR614 router with USB Cable Modem
When working with routers, CAT-5 cables are the more usual cable used. Your modem's Ethernet Port --- connect it via cable to the router's WAN input. Connect one of the router's LAN outputs to your computer's LAN input with another CAT-5 cable. Go through the appropriate Router Setup by putting http://192.168.1.1 into your Internet Explorer, with ' admin ' for User Name, and no password (just press Enter in Password frame). Once you are in to the router setup, you can select your Network Name (SSID) and then implement whatever Security you might want to use. You should be up and running by now, nhave lots of fun!
Dec 18, 2009 | NetGear WGR614 Wireless Router
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
21 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
