Question about Kitchen Ranges
Replacement part Westinghouse hakea gas oven temperature knob
  • Anonymous Apr 24, 2009
    Hello- i am looking for the same thing. have you spoken to westinghouse spare parts? I'm going to do the rounds of the spare parts suppliers in the next few days- let you know if i ever find anything! you may have bought a new one since then..
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Posted on Feb 26, 2008
housejess
  • 317 Answers
SOURCE: My gas oven overheats and burns my baking. With
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Posted on Nov 16, 2009
How do I turn on my Westinghouse 613 oven please?
Select the function on the far left knob. Select your temperature with the knob second from left. Select the cooking time with the knob to the far right.
Dec 24, 2017 | Ovens
Westinghouse oven no gas but supply and power is good
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Jan 12, 2013 | Westinghouse WGQ332HS 5.7 cu. ft. Gas...
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
Oven is not holding correct temp
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
When you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, and then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Let us know if you want something else please accept the solution.
Jan 02, 2011 | Maytag MGS5770 Gas Kitchen Range
I don't have the model number for this range but it's a very old magic chef gas oven. What I need is the oven temperature knob. The knob used to have all of the temperature numbers printed on it however...
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Jan 16, 2010 | Magic Chef 9122 Gas Single Oven
Numbers missing from Westinghouse oven knob, plus burner troubles
ok put a pan of water in your oven with a cooking thermometer in it. Turn your oven with the new knob you just got from repair shop. They are in the yellow pages Lots of laid of repair guys went out on there own. So they work at a lower price. As i was telling you.set your new knob @ 9:00 leave it there long enough to even out 10 minutes will do. next set it @10:00 next 11:00 @12:00 and so on. Till you get all your settings are compleat. Happy cooking from sawdust46
Aug 08, 2009 | Kitchen Ranges
Need replacement temperature knob for Westinghouse Roaster Oven
Hi, If you get me a make/model#, I can look this up for you.
Vic
Jun 27, 2009 | Ovens
Oven Temperature Sensor
it's just not just the sensor ,it's the thermostat which is on the back of oven knob. that sensor is part of the thermostat it's all one of the same part. to check the temperature put a thermometer inside the oven and set the the oven knob at 200 degrees. 20 minutes later check and see what temperature it's inside the oven, to regulate the temperature many of the new ovens are set from the factory, It can not be calibrate, on the older ones the adjustment screw is inside the shaft when you take the oven knob of, it's inside the shaft.
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
Westinghouse self cleaning oven manual or owners manual
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Dec 08, 2007 | Kitchen Ranges
Kitchen Ranges Logo
282 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
