Question about Master Lock Cycling
No directions came with Master Lock 8143d. Do not know how to set combination to unlock and then set for my use?
  • 4,348 Answers
The information "out there" is that this is a fixed combination lock, meaning not changeable.
Posted on Mar 13, 2011
I forgotten my skybag number lock how to open the lock .
You can try to determine the combination by pulling on the shackle and moving the combination wheels until one of them clicks (or feels) different from the other numbers. Do the same for the other two number wheels. Lots of trial and error, but it has worked before.
http://traveltips.usatoday.com/unlock-threedigit-combo-master-luggage-lock-109482.html
Feb 05, 2015 | Master Lock TSA Set your Combination Lock...
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
I just bopught a master lock 1590d and theres no password to unlock it for the first time plz help
  • Set your own combination using 3-letters or numbers or a mix of both
  • Combination easy to change with included reset tool
  • Maximum security with anti-shim feature
  • Hardened steel shackle for increased bolt cutter protection
  • High precision dial clicks for fast accurate dialing
Aug 16, 2011 | Master Lock 1590D Set-Your-Own Combination...
I found my old masterlock combination lock it has a serial # but I can recall combination for use. I want to use it for gym locker.
had your looking for a combo, throw it out. no way to find the combo for it. serial only refers to the model of the lock. its like asking for a part for " my ford truck " not enough info.
Mar 12, 2011 | Master Lock 1590D Set-Your-Own Combination...
How do I unlock a Master TSA002. I do not know the combination and I don't know what tools I need. I have important court papers in the safe and the spouse won't give me the combination. I know the...
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Dec 18, 2017 | Master Lock 5400d: Portable Select Access...
I unlocked my lock and set my new password but when i tried to oped it it wont openn itss very frustratin !
It would appear that you made a mistake in setting your new combination on your Master Lock 5400d. The only way to open your lock is by using the correct combination. There is no other way. Most mistakes are normally one or two digits out, so yo may wish to try variations on what you thought you set.
Apart from that you can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination
Oct 03, 2010 | Master Lock 5400d: Portable Select Access...
My Brass Master Lock Combination Lock is refusing to unlock. A couple of the combo numbers seem to be "sunk in" a bit. I tried WD40 but still will not unlock and I need to open my gate. This lock...
You need to make sure you are putting the righ combination. Try to put it the opposite way also for example
3645 or 5436
How many numbers are in the combination?...if it is a 3 number system it should be easy.
Artgirl
Jul 18, 2008 | Master Lock 5400d: Portable Select Access...
Hotel Lock
you need the master remote for this model to unlock since it is a "motel set" also you will need the owners manual you will find both by googleing the model
Oct 15, 2007 | Televison & Video
Cycling Logo
890 people viewed this question
Top Master Lock Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Master Lock Cycling Expert? Answer questions, earn points and help others
