Question about Exercise & Fitness
Display comes on but walking surface does not move
    Problem Solver:
  • 17 Answers
Hi, check for a reset button otherwise i would need more info on the treadmill to better diagnose whats wrong with it. Thanks, good luck, Bob
Posted on Mar 13, 2011
How to adjust treadmill belt
Whet taking off the rear cover on a Trojan treadmill. there is 2 threaded bars with nuts on them. you can adjust there. be sure to adjust them same turns per side or you may have problems with imbalanced belt
Feb 26, 2015 | Exercise & Fitness
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
Everything but walking belt working
not for sure but i would look for an access panel and look to see it the drive belt has come off the pulley or if the drive motor has come unplugged.
Jan 19, 2013 | Reebok TR2 PremierRun Treadmill
When starting, the motor starts sluggishly. It sounds different and goes very slowly. At higher speeds, way high, it runs fine. Speed censor says one thing, but tread moving very slowly.
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Jan 05, 2011 | Proform 595LE Treadmill Walking Belt
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
What should I do if the treadmill walking belt slows while in use?
Sounds like your walking belt is starting to get worn,.or you need to lubricate the walking belt. Try applying a silicon lubricant, or other lubricant called for in your manual, to the bottom side of the walking belt, and the surface it contacts. ( not the drive roller).
Jan 28, 2010 | Exercise & Fitness
Tripping out every 5 mins or so
If using an extension cord try plugging directly into wall. If not check the deck under the walking belt for worn surface (wood should not show) Purchase the silicone lube designed for your model and re lube the walking surface under the belt. The motor is overheating and pulling too many amps and the fix is to reduce friction. (You may notice the problem being more pronounced the heaver and larger feet the user has)
Eric
Jan 19, 2010 | Precor Exercise & Fitness
The walking surface does not move except for a little jolt every now and then,why?
The max speed potentiometer needs to be adjusted during calibration, that usually fixes it.
Oct 17, 2009 | Nordic Track Exercise & Fitness
Accurate when still display changing inaccurate
You might have air bubbles trapped on surface of transducer. Use soap on it so water sticks to surface, no wax, oil, or grease.
If transducer is mounted inside the boat, you have air trapped between it.
Jul 12, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
Need to move treadmill downstairs and can't fold and secure it
Typacally heavy movers will use pallet wrap, which is industrial size and strength plastic wrap, this is available where ever moving supplies are available. (UHaul, Truck Rentals, or storage facilities.), fold up the machine and wrap it well with the wrap. This will also protect the machine, and the walls as it should prevent paint transfer on those slight OOPs.
Hope this is of some help.
Ed
Apr 25, 2009 | Office Equipment & Supplies
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
