I have a riello burner for my central heating system. When i turn the heating on the burner ignites for a few swconds and then goes out.... the burner tries to re-ignite and the same happens. I have plenty of oil and tried to clean the fuel nozzle and electrodes as I thought it may be dirty. I still need to clean the inside of the boiler free of sut. Can you tell me if I need a new photocell, pump or something else
Ireplaced the photocell which was blinded and the burner started and stayed lighting....
Thanks for all your help
Posted on Aug 05, 2008
  • 1,420 Answers
Replace the nozzle, don't try and clean it. After the burner runs a few seconds, do you have to reset the control (red button) before it will start again? Does it sound like there is a pulsation in the flame when it starts or it is running out of oil? You may have a bad ignition control. Start with the small stuff, nozzle, strainer filter, oil tank filter and then work to the more complicated.
Posted on Aug 04, 2008
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: burner propblem
have you tried to wipe off the fire eye on the unit if it has one? If it's dirty too then it will not see the flame and not let the unit come on correctly. Good Luck and have a Happy New Year.
Posted on Jan 05, 2009
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
Pilot light out....buderus furnace but a red riello ingniter on the front....I've watched my fuel guy flash a light into it this baby when out before but need to do it myself now.....could you walk me thru...
This is due to a "Lock-Out" Check your flame sensor for carbon build up. Possible heat exchanger blockage.
The reason he used a flashlight was to trick the burner into seeing a flame, not a good idea for a novice.
Mar 16, 2011 | Heating & Cooling
Riello oil burner problem - Furnce blower starts on thermostat call but Riello burner needs to be manually reset for ignition.
BUrners trip on safety for a number of reasons. When the burner is working you should not see any smoke in the smokepipe. If you do then the settings are off and adjustments need to be made. If the unit does not actually light then the problem can either be with the nozzle, the oil pump or filter. Lastly, you may not be getting spark. If you get more specific I may be able to guide you through step by step.
Feb 02, 2011 | Heating & Cooling
Riello oil burner RDB Hi everybody i have a Riello oil burner RDB . I am wondering is there a way to make it more oil efficient?
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
Sep 25, 2010 | Heating & Cooling
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
I have a riello oil burner, starts to fire up for a few seconds and fails , fuel is ok any ideas please
i have a riello oil burner 40 F5, starts to fire up for a few seconds and fails , but then it will start for a few minutes...then shuts off... house is not being heated sufficient. There's hot water but after one shower the water starts getting cold....fuel is ok any ideas please
Nov 28, 2009 | SySTOR Systems (400S52) Burner
Burner propblem
Jan 05, 2009 | Heating & Cooling
Riello burner will not pump oil to nozzel to burn.
Revisit the photocell:
1. Check if you connected the socket end, into the two pins properly, as it is possible to miss a pin.
2. Try to borrow a working photocell or use yours in another burner to make a determination.
Dec 27, 2008 | Heating & Cooling
Heating & Cooling Logo
647 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
