Question about Lincoln Welding Tools
I HAVE A LINCOLN WLDER T140 WELD GOOD . BUT KICK MY HOUSE BRAKER EVERY 5 MIN. I AM TIRED OF THIS PROBLEM. I WILL APRECIATE YOUR HELP . THANKS.
  • Lincoln Master
  • 43,501 Answers
The problem could be a bad breaker... often after heating up a lot they do go bad...I would check the amperage draw if you have access to an amp meter and make sure that the draw is less then the rating of the breaker...otherwise just change the breaker and see if it helps...
The amp draw of the welder may also be too much for that circuit...are there any other loads on that circuit, lights?? or any thing else...that may help to overload it...
Also if you are using an extension cord make sure that it is a thick enough gauge cord to handle the current...
heatman101
Posted on Mar 13, 2011
My lincoln ranger 8 has excessive weld spatter compared and the auto idle dosent kick in very fast when I strike off to weld delayed or sticks my rod. My other ranger 8 no issue same heats. Also
weld current and idle control on this machine is controlled by the main circuit board, you mention that you a second ranger 8 that does not exhibit the same problem, you are fortunate in this, remove the board from the functioning machine, install it into the troubled machine, this should correct your problem, you can contact a weld supply store to purchase a replacement pc board
May 27, 2015 | Lincoln Welding Tools
Weld-pak 100 Hd Problem
There is a reset button located in the wire feed spool compartment,
check to see it stays in when pushed. It is a safety when the machine
overheats, it normally resets when machine cools off. If it is working properly I suggest contacting Lincoln Electric Dealer for service.
Mar 03, 2012 | Lincoln Welding Tools
My lincoln 225arc welder wont weld
Have you disconnected the transformer wires from the block in the back and used an ohm meter to see if you are getting a reading through the wires? If you don't have a reading or no beep then you may have a bad transformer. Also check the wiring running from the block to the transformer to make sure the wires are not burnt or coming loose. Have you tried to weld on different settings? Look on the back of the tremels to make sure you don't have burnt spots on the switches. Make sure leads are good and ground is good.
Mar 30, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
20 kick always know won't run
check you valves. you shouldn't have to kick it 20 times. a good running motor is a 2-3 kick let me know if this helps if not i'll help till the things is running
Mar 10, 2010 | 1991 Suzuki DR 350 S
How do you ignite a Lincoln Electric Welder???
You don't need an striker with a MIG welder just hook the ground cable to the base metal point the nozzle where you want to weld and pull the trigger and it will weld. Household current will run a MIG welder Take a look at the plug on the welder if it will pug into a 110v outlet you are all set, but most likely you will need a 220v outlet and maybe as much as an electric dryer type outlet.
It takes a lot of practice to be a decent welder you also need to know what voltage and wire speed settings to use for a given thickness and type of material.
You don't mention shielding gas, if you are using a flux core wire you don't need it, but if you are using regular wire you do.
If I may make a suggestion, If you really want to learn how to weld, find a community college near you and take an introductory welding class. You will get a wealth of information and practice on different welding processes. The instructor will work with you and get you welding much better and faster than you will on your own. Most importantly you will get a lot of safety information.
This is a good introductory book:
http://www.amazon.com/Welders-Handbook-RevisedHP1513-Cutting-Oxyacetylene/dp/1557885133/ref=ntt_at_ep_dpt_1
Mar 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
70 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
