Question about Microwave Ovens
My micowave oven ge hvm1750sm1ss dosen't have power on and the fuse does work and the switch on the door works to whats wrong with it.
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
rylee_smith
  • 8619 Answers
SOURCE: Microwave has no power
Hi
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Thanks
Rylee
Posted on Jan 15, 2009
  • 10865 Answers
SOURCE: kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Posted on Jan 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Posted on Sep 26, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Profile Convection Microwave Oven - Convection not working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Posted on Sep 30, 2010
GE microwave HVM1750SM1SS
Check for power to the wall plug. Then check for 120Vac at the input to the circuit board power supply. Then check the power across the fuse on the circuit board. if power readings are all correct you have either a bad relay, a door lock that's u/s, or a bad main board. Whats very common with microwaves is the control panels push buttons stop working. Many times its because grease and oil gets under the board and between the buttons and the circuit they activate underneath. To fix it. Unplug the the unit, DISCHARGE the high voltage capacitor. Make your way to the control board button overlay, remove the overlay. clean back of overlay and all contact surfaces on the borard. Re-install and try it again. It many work!
Aug 31, 2014 | Microwave Ovens
GE Microwave model hvm1750sm1ss table wont rotate
The turntable motor has seized up, the only solution is replacement.
Jun 15, 2012 | GE Microwave Ovens
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
My microwave power is ok, led light ok, but dosen't work what problum?
check the door switches....i had an over the oven micowave with a bad door switch....thing is the switch cost 35.99 online and i bought a counter top microwave for 39.95 at walmart
Jan 31, 2012 | GE Microwave Ovens
GE Microwave model hvm1750sm1ss powers up fine, table rotates, lights on, but does not heat up item
heatman101
Sep 12, 2011 | Microwave Ovens
Magic Chef VM11EB-8P micowave oven act like nothing is wrong ,but will not heat .make all regular noises like it is working
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 27, 2010 | Microwave Ovens
Micowave works but no heat fuse is good mw8992rcd,what other checks can i do thanks wg
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Sep 30, 2010 | Emerson Microwave Ovens
Hi
Thanks
Rylee
Jan 15, 2009 | Whirlpool MH7135XE Microwave Oven
No power whatsoever
if this helps please give me a fix ya vote
Jul 14, 2008 | GE Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
