E41 shown when diagnostics ran on zanussi essentials washer dryer. Have no idea where filter is on machine but can access filter pipe at bottom right. Machine 1/4 full of water and clothes, door will not open and machine will not run although all dials/displays working correctly.
    Scholar:
  • 158 Answers
E40 refers to a door interlock failure and E41 refers to a faulty connection between the computer board and the control board. Unplug the unit before anything is done!
You have to take the top rear cover off to access this and check the connections between the two.
You might also want to remove the PCB from the white plastic housing and inspect for any burnt tracks on the board. If it looks good you should be able to firmly plug the harnesses back in and be good to go.
This poor design is a common problem and results in connections coming loose due to miniscule vibrations from machine operations
Posted on Mar 13, 2011
Can dial in programme but when start is pressed all leds and display go out and it bleeps once. Eng mode gives E41 as last error
E41 means door open or the machine is not able to lock the door
(door delay interlock does not close after 15 seconds).
Possible causes:
door open, door delay interlock, wiring, main PCB.
Dado
May 04, 2016 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi washing machine will not empty
There should be a filter located at the bottom right front of washer behind a drop down down cover.
Unscrew the filter anti-clockwise to remove and clean.
If filter clear, then possibly the pump is faulty.
Hope this helps you with your problem.
Dec 02, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
Mar 19, 2009 | Zanussi ZWF1430W Front Load Washer
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
212 people viewed this question
Top Washing Machines Experts
