Question about Sony Playstation 3 (PS3) Console
My dad came back from Iraq with a ps3 and it won't show up on the tv (av cables) we tried it on an hdmi that didn't work we also tried holding the power button down that dident work so can you tell me what's wrong?
    Genius:
  • 1,043 Answers
Even though your PS3 was bought in a country that uses a different TV system than the North American system, it will not effect your ability to use it. The PS3 was made to be used with the HDTV format which is universal regardless of which country you are in. The problem you are experiencing has to be either the inputs of your TV, or an issue with the PS3.
If you are already using other hardware with your TV, such as a DVD player, and you are able to use those inputs, then we can eliminate the TV. That would mean there is something wrong with the PS3. If the PS3 is starting up normally, and your power light is not blinking (which is a built in diagnostic program), then there may be an issue with the outputs of the PS3. If the cables you have tried to use with the PS3 work on other units then we can eliminate that issue. The problem would then be the internal components of the PS3. Try this;
1) Press and hold the power button long enough for it to power on and then off again.
2) When it goes off press and hold the power button again until you hear 2 beeps. As soon as you hear those 2 beeps immediately let go of the power button.
3) At this point you should get a display and the system will ask you to connect the controller.
4) Plug in the controller and you should then see a menu on the screen like this:
  1. Restart System: Restarts the PLAYSTATION 3 System.
  2. Restore Default Settings: Reset all system settings back to default.
  3. Restore File System: Checks for corrupt/missing system files.
  4. Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
  5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
  6. System Update: Update the PLAYSTATION 3 System
If you are able to see this menu try each of the items and then check to see if your system will start normally. DO NOT GO ANY FURTHER DOWN THE LIST IF ONE OF THE CHOICES RESOLVES YOUR ISSUE. Depending on how far down the list you go you may lose any saved information such as games or scores.
If you are not able to see the menu at all then your problem is internal to the components. At that point you will have to take your PS3 to a repair center and have them take a look at it. Ask them to give you a quote before they fix anything as the repair may end up costing you more than what your Dad paid for the unit.
Posted on Mar 13, 2011
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
I have a new slimline DVD and a sony bravia HD tv. My PS3 worked with the basis cable and I recently purchased an HDMI cable and now it won't work on any of my 6 AV channels, including 1 of the 2 HDMI...
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection works but not std rca AV
You must set it OFF HDMI while connected to the TV...
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not conecting on 2 samsung tvs
Your ps3 could be in component mode. You will have to hook it back up on component mode, and go to the ps3 menu and change the setting to hdmi.
Aug 11, 2009 | JVC LT-37X776 37 in. LCD HDTV
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
