Question about ICOM Informatique Floating Hand Held Vhf Radio, Icom M34
Icom IC-M34 transmit correct but do not receive if sql is above 0
  • mikedbom
    mikedbom Nov 27, 2012
    I have the same problem. Can transmit but not receive. The speaker works as you can hear the sql and aquaquake. anybody else have a better idea?
  • Michael Nassif
    Michael Nassif Dec 29, 2013
    check rx IC
  • 35 Answers
Sound like a speaker problem, dosconnect the speaker and check it with a meter, it should read 8 ohm. Good luck.
Posted on Mar 20, 2011
  • 1 more comment
  • jumblesa Mar 26, 2011
    that suggestion does not work as you could hear the beeping thru the speaker as you touch the radio buttons or if you set the squelch to 0 you could hear the noisy reception..... any other suggestions?
  • antonio_pint Mar 28, 2011
    is not a speaker problem, the speaker work fine because i can heard noise and strong signal with the squelch set to zero level.
  • Evileye Jul 08, 2013
    Apparently its a design fault with the IF Filter. Needs to go back for new IF filter.
Why won't my ic-m34 doesn't receive - Icom Ic-m34 Vhf Waterproof Marine Two-way Radio
If it can receive some signals that are close to you, then the RF front end protection diodes are likely shorted. This would require someone with expertise in surface mount components to repair. Take it to a dealer and have them look at it.
Sep 07, 2017 | Icom Radio Communications
Check Rx sensitivity if low then change filter
May 11, 2014 | Icom Ic-m34 Vhf Waterproof Marine Two-way...
Radio not receiving on any channel
Hi Mike,
The manual for this radio (in Adobe .pdf format) is available for download directly from Icom America, free of charges.
Since the "AquaQuake" function works and you do hear static when the squelch is off, that is sufficient to let us know that the voice coil of the speaker is functional and should produce sounds with the right signal applied.
The first thing to determine is if you're close enough to another operating transmitter for the radio to receive a signal. One of the 10 weather channels the radio is capable of tuning should be close enough produce some intelligible audio from the speaker - assuming the squelch setting isn't set too high.
If a WX channel works, then you'll need to see if there's a VHF Marine band transmitter operating nearby. You might need to set another Marine band radio receiver up to verify that there is indeed a signal present on the particular Marine band channel that you're monitoring. A list of frequencies is published on pg 27 (of the manual linked above) in case you need to convert between channel and frequency to tune on a non-channelized radio.
Outside of that, there's little the end user can do without specialized test equipment, schematics and of course, training. Many shops will be happy to provide an estimate for repair when provided with a small bench diagnostic fee. This fee is usually applied towards an authorized repair by most reputable repair shops.
I hope this helps & good luck!
Nov 27, 2012 | Icom Ic-m34 Vhf Waterproof Marine Two-way...
Dear sir I HAVE VHF MARINE TRANSCEIVER IC-M34 for 2 years ago, suddenly, I can't receive any signal ( transmitting without receiveing ) but if I set the squelch to 0 level I can reveive signals and...
This is a front end issue that has to be remedied by a radio tech or the factory. The front end is the receiver and it takes special tools and equipment to test and calibrate it correctly,, The only thing you can do is check the ICOM page to see where it can be serviced.
Nov 27, 2017 | ICOM Informatique Floating Hand Held Vhf...
I have an ICOM-504 . I can transmit but I can not receive any chanels even the WX is not receiving
I had the same problem and traced it to a bad connection between flex cables and boards.It seems the SQL signal from the Rx board is not reaching the processor on the front panel. Check all connections (reseat all cables) and try again.
servstan
Aug 09, 2010 | Icom IC M504 Black Submersible PLUS Marine...
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
Icom F21
It's a frequency error. It can be corrected, just give me some time, I need to figure something out first. It might take me a day or two.
Sep 06, 2008 | Icom IC-R5 Handheld Scanner
ICOM Informatique Floating Hand Held Vhf Radio, Icom M34 Logo
2,471 people viewed this question
Top ICOM Informatique Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an ICOM Informatique Boating Expert? Answer questions, earn points and help others
