Question about Freud FT2000E 3 Router
MY router model FT2000E runs about 1-2 seconds and stops. I'm looking for the possible cause and possible solution. Router has not been used for about 7 years.
  • DannyVT Mar 15, 2011
    Thanks, I will investigate this solution.
  • 5,603 Answers
Check brush length. If they are OK, likely the speed control has a failure.
Posted on Mar 15, 2011
Looking for a switch for Freud FT2000E router
You can contact Freud directly, they do have large U.S. operation and carry most spares. The Parts and Repair department is (800) 334-4107 to order the parts you need.
Jan 17, 2015 | Freud FT2000E 3 Router
I LOOK FOR POWER SWITCH KEDU HY 15 B FOR A ROUTER
Hello my name is Larry Boccioletti.
I am a Freud service dealer in Canada. My company's name is Halton Maintenance Centre. my email is haltonmaintenance@yahoo.ca
all I need is a model number of your router.
Thanks
Larry
Jun 23, 2014 | Freud FT2000E 3 Router
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Mar 23, 2014 | Freud FT2000E 3 Router
Froud ft2000. Cannot spin motor. seems seized using it, stopped, then would not restart
Hello Ron my name is Larry I am a Freud dealer in Canada if you still have the router I can get you parts
Oct 11, 2013 | Freud FT2000E 3 Router
Ft2000E router switch
Hi There I am a Freud dealer in Canada I have switches in stock.
If you wish a quote just send me an email request and I will be happy to.
My Name is Larry Boccioletti and my companies name is Halton Maintenance Centre and my email is haltonmaintenance@yahoo.ca
Larry
Jan 24, 2013 | Freud FT2000E 3 Router
My Ft2000E Freud router stopped working when I was setting up to run some moldiings. No humming . no burning= nothing. Any Ideas?
Hello Blonsan I am a service dealer in Canada and the speed control will do that no warnings ---the speed control is 89.00 canadian ---give or take--
Nov 04, 2010 | Freud FT2000E 3 Router
Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Dec 05, 2009 | Freud FT2000E 3 Router
Ive got a kenzo router and the router bits do not fit . ive got quarter inche cutters and when the collet is done up tight the cuters are still not tight. its not a half inch router as ive measured it. any...
Your router bits must have a 6mm shaft, whereas your router with the collet closes down on a 1/4" or 6.4mm shaft. You will need to get a metric collet for your router spindle, or get a new set of 1/4" bits
Sep 28, 2009 | Freud FT2000E 3 Router
Freud FT2000E Brushes
You have a couple options, I found a website for Freudtools.com where you can find a dealer near you or you can call Freud direct at 1-800-334-4107 to order the brushes. The part number I saw that you need is 13413.9073 but you might want to double check me on that . let me know if I can help further
Feb 18, 2009 | Freud FT2000E 3 Router
Freud 3 one fourth plunge router variable speed won't run
Hi
First check the power suply cord(conductivity),the on/off switch, the fan and the armature,the brushes and the wires.
best regards savumihai71
Jan 05, 2009 | Freud FT2000E 3 Router
Freud FT2000E 3 Router Logo
208 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
