Question about Dishwashers
My dishwasher has a leak around where the motor and pump connect. I tried to tighten screws, but they are tight. Do I need to replace pump? GE Appliance Website says that pump is no longer available. This dishwasher was purchased around 1998 timeframe. Thank you.
  • ghowe80 Mar 13, 2011
    Sorry. The type of dishwasher is GE Profile. The model number is: GSD4030Y70WW. I appreciate any information that you can give to me.
    Thank you,
    Greg
    Thank you very much! I will start with replacing those components. I will order them today.
  • 4,323 Answers
Hi
Though it seems that the pump should be replaced however, please post back with the model no of your GE dishwasher. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 13, 2011
  • Daniel Scott
    Daniel Scott Mar 13, 2011
    After checking its parts in this diagram....I believe that motor and pump are fine rather it is the impeller kit causing this issue and should be replaced.
  • Daniel Scott
    Alright....
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Water leaking under dishwasher, around motor
hi friend,
    Tightening the fittings
  1. Step 1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
  2. Step 2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
  3. Step 3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
  4. Step 4221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
  5. Leveling the machine
  6. Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  7. Step 2 Open the door completely and remove the bottom dish rack.
  8. Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  9. Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  10. Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  11. Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
  12. Fixing a leaking door
  13. Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  14. Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  15. Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  16. Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  17. Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • If your dishwasher has an air gap, which prevents dirty water from re-entering the machine, clean it regularly. Otherwise, it could overflow and leak.
  • Always use detergent that's made for your dishwasher. Dishwashing liquids and other soaps can create excessive suds that will leak from the machine.
  • Occasionally, the main seal between the dishwasher cabinet and the pump fails. If your dishwasher leaks at this spot, have a professional replace the seal.
Who Can Help Sponsored hope this helps u
please rate me.....................
thank u for using fixya
regards
sivaranjini
Nov 30, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My GE Profile dishwasher is leaking under the tub. Its not a small leak, the water comes out as soon as it starts to fill. What may be the problem?
You have one of two problems here. First of all remove the lower front panel on the dishwasher and get down there with a flash light and check it all over. The water leak is either where the water line is connected to the machine, or around the motor/pump seal. Close the door and turn on the machine. Now you will see exactly where the leak is. IF if is the motor/pump seal you may want to call a technician. If it is where the hot water feeds the dishwasher you may be able to tighten up the connection.
Apr 20, 2009 | Dishwashers
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Nov 22, 2008 | GE 24 in. GSD980X Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking from rear in cabinet
  • Lower rack
  • Spray arm
  • Spray arm support
Sep 30, 2008 | GE Nautilus 24" Built-in Dishwasher
Leak from dishwasher
I currently had the same problem with mine and the culprit was the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Mine had dry rotted and leaked very badly.The part as only about $10. Hope this helps
Aug 04, 2008 | GE 24 in. GSD4060JSS Built-in Dishwasher
Leaking water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | GE GSD1180X Dishwasher
Leaking problem from the door
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
May 03, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
