Question about Panasonic SC-PM28 CD Shelf System
Panasonic SC-PM28 cd player keeps skipping , even after cleaning
4 Suggested Answers
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
  • 15 Answers
SOURCE: RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Posted on Jun 24, 2008
SOURCE: TECHNICS SC-EH750-CD KEEPS SKIPPING
Sorry , not worth the hassle , bin it and get a better system second hand for around £25
Posted on Jan 26, 2009
Technics SC -HD 501 CD jumping and skipping
If this happens on all CDs then most like the drive is bad or lens is dirty You can try cleaning out the heads using a cleaner disc. If you have a way to get to the lens you can try cleaning it manually. But most likely. It's one of the following dirty lens, bad motor, bad speed control.
Nov 16, 2011 | Audio Players & Recorders
Panasonic CD player model #SC-EN7: CD will not play, keeps saying "reading disc", but the disc does not spin, the transverse deck has been replaced with no change in status.
There may be dust inside the unit on the laser. Try shoting some compressed air in the CD drive area to clean out. Also, ensure that the CD surface is clean, and try a different factory made audio CD. Sometimes CD players have problems reading "burned" CD's.
Apr 14, 2010 | Panasonic SC-AK70 Shelf System
Panasonic Stereo system SC-PM28 will not eject any of 5 CDs in stack. Tape deck OK, as is tuner. Any ideas please.stellamurg
These units are known for getting out of time. There is an engineering modification that can be done to prevent this from happening again. Your best bet is to bring it to a Panasonic authorized service center. They will rebuild the CD loading mechanism and make the appropriate changes. I have made this modification numerous times and have not seen a return of the problem once completed.
Dan
Mar 06, 2009 | Emerson MS9700 CD Shelf System
How do you reset the 5 cd disk?
Try this to rest unit.With cd selected press and hold 'Stop' for about 5 sec. keep holding then press and hold 'skip FF' for about 5 more sec. Take off power then unplug unit, then power back on. A line shows across the screen if it works.
Nov 10, 2007 | Panasonic SC-AK78 CD Shelf System
CD Reading Problem
Did you try cleaning the lazer?
Jun 07, 2007 | Panasonic SC-PM28 CD Shelf System
Cd's skipping
Try first to clean the lens with a lens cleaner disc. or cleaning the lens manually. if that does not help, then im afraid the unit has come to the end of its usefull life. and is time to get a new one . Good Luck
Oct 05, 2006 | Panasonic SC-AK110 CD Shelf System
CD player
Feb 12, 2006 | Panasonic SC-AK29 CD Shelf System
Panasonic SC-PM28 CD Shelf System Logo
91 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
