Question about Ovens
Hi, i have a Neff circotherm oven. It has error code -5P. What do I need to do? thanks
SOURCE: clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Posted on Mar 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff Circotherm Double Oven keeps blowing
I assume that you are fitting genuine elements, as opposed to cheap copy ones..
Make sure the fan is working o/k as well.
You also need to check the temp is correct, for this you need to have a oven thermometer to check it with.
Make sure the connections to the element are o/k as well.
Hope this helps with your problem.
Posted on Dec 12, 2009
apart4u
  • 213 Answers
SOURCE: neff circotherm doudle oven main oven fan working
For all Free appliance repair videos visit our VIDEOTUTORIALS1, If the fan motor in the back of the oven is going round and thetemperature light is on (normally little red light), but there is no heat thenyou will probably need a new oven element, these are generally very easy to fitand readily available from our website these can be tested with a electricmeter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then youneed To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
apart4u
  • 213 Answers
SOURCE: I have a Neff U1721 circotherm oven. The lights
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
Neff fan oven broken
Element blown-part 499003.Cheap repair
Apr 08, 2009 | Neff B1881 Single circotherm super...
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Neff faulty Fan
Hi.
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Neff double oven
Hi, Have the same problem today.
Found the following on you tube that may help you!
http://www.youtube.com/watch?v=hSzc4Uqbbr8
Best Ian
May 10, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
