I have a Kenmore Series 80-Model 110-16862503. I need to get into the control panel and can't figure out how to take the cover off.
  • randy_rendig Mar 14, 2011
    I'm going to email several photos to you of the front and back of the washing machine as I'm not understanding what exactly to do.
    Do you have an email address I can submit photos to as the above isn't helping and I thought if I sent pictures of my machine it might help.
    Thanks.
  • 8,197 Answers
To learn how to get in the cover look at the links below.
In order to access the control panel in the service position, disconnecting the lid switch harness, prying the two cabinet retainer clips off and tilting the cabinet forwards and walking it away from the washer. I added three images below to reference for instructions. Note: Your console will look different than the one in the second image, but the procedure is the same for releasing the console from the top. Note: Be sure to disconnect the power cord from the power source before servicing your washer.
http://www.managemylife.com/images/2949/original/11016862503_console_and_back_panel.jpg?1288954019
http://www.managemylife.com/images/2950/original/calypso_parts_location_3.gif?1288954190
http://www.managemylife.com/images/2953/original/DD_cabinet_removal_1.png?1288954256
Posted on Mar 13, 2011
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
Jul 07, 2011 | Kenmore Washing Machines
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Dryer really squeals
Ok this is a really broad question, Kenmore will squeal when a belt tensioner or motor bearing is out, a frigidaire or small kenmore with control panel above the door and serial number starting with x will squeal when the bearing is out on the drum or the motor. This is a general cover on dryer noise with a model like Kenmore series 80 I can give solutions ok?
Sep 20, 2008 | Dryers
Kenmore Series 80 won't stop filling.
Kenmore washers
Fill switch
pull off fill knob
remove plastic trims from front face ends of control panel exposing screws
remove phillips head screws from bottom
slide control panel forward & up ~1inch then flip over backwards on top hinges
to remove fill switch
depress lock tab right side where switch body touches back of control plate
rotate counter clockwishe 45-90 deg
withdraw fill switch
remove plastic tube from switch body
Blow any water out, should be empty when washer is empty messes up pressure sensing
refit plastic tube
adjustment screw is 1/8" hex head bolt next to knob shaft
clockwise raise water level
counter clockwise lower water level
can be operated in this open position to check operation, may have to move switch between fill positions to restart fill operation
Nov 27, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
