Question about Electrolux Lux 7000 Bagged Canister Vacuum
I have a electrolux 7000 my cord brok off and it got succked in. igot it apart. I DONY KNOW HOW TO PUT THE COIL SPRING ON THE POWER CORD WHEEL. NEED HELP
  • 694 Answers
This is very difficult to reassemble correctly, and more difficult to explain properly. You need to take the vacuum to the nearest authorized Aerus Electrolux store for reassembly. Or call for free pick up and delivery.
http://www.aerushome.com/storelocator/
Posted on Mar 13, 2011
  • Sara Mcauliffe Jul 16, 2011
    Another option now that you have it apart, is to just replace the entire cord retract. You can find them internet wide for about 40.00.
How to replace electolux 7000 cord
These canisters are not easy to change the cord in. If you're somewhat handy and know how to disassemble the machine, it is more cost effective to just order a cord winder complete assembly and switch them out yourself! It's most likely less expensive than the labor and parts you'd pay to have it completed! I have them! Hope it helps! Thanks!
Aug 26, 2014 | Electrolux Vacuums
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
I need to know the correct position of the rear wheel assembly and spring to istall in a electrolux renaissance power nozzle model#n106a in the base.Is this power nozzle refered to as PN5,6 or7? I also...
any Aerus deler will have the plate go to aerusonline.com they have dealer listing in your area. Beware they will try to sell you a new one. Part should be around $10 you may want them to put that axle and spring and cover on it is hard to do. A hint though for a DYI the spring barb goes in a little square hole in the weel channel. Good luck .
Apr 03, 2014 | Electrolux Guardian Bagged Canister Vacuum
Lux 7000 power nozzle
Fixya can't but maybe Electrolux can If you ask.
Dec 22, 2017 | Electrolux Vacuums
I can't recoil the electrical cord. What do I need to do?
Open the bag door, remove the bag (leave door open)and then with a hammer and a blunt instrument(wooden dowel) Strike the side rubber "bumper" rails towards the open door side of the machine from the back of the vacuum. You should get it started and then it should easily pull out from both sides. you can remove the bottom of the vacuum and remove the cord "guard" to allow the cord to go thru also. The back is held on by the union of these two halves by dowel pins(plastic nubs) Sometimes the "spring" mechanism gets jammed from over pulling. Just simply roll the smaller wheel to retract the cord manually. You could try spraying the rollers with a silicone or graphite type spray to allow free movement of the spring. Hopes this helps. WFServices
Jun 25, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Return cord on electrolux canister vacuum with bag purchased in 1969
Your machine should still be under warranty which is voided if you do the work yourself or have another vacuum shop do it for u.
Aug 03, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Retractable power cord
JUST LIFT OFF THE TOP HALF. CAREFULLY REACH IN FROM THE LEFT SIDE AND DISCONNECT THE CLEAR PLASTIC HOSE THAT IS ATTACHED TO THE "DIAL" ON TOP OF THE MACHINE. THEN LAY THE TOP HALF OF THE MACHINE TO THE RIGHT. DON'T DISCONNECT ANY WIRES. YOU'LL HAVE TO HAVE A NEW CORD WINDER (LOOK ON E-BAY). THE MOTOR AND CORD WINDER ARE ATTACHED TO EACH OTHER BY WIRES AND CAN BE LIFTED OUT OF THE CANISTER.EVERYTHING YOU DO JUST REMEMBER THAT ALL OF THESE PARTS ARE ATTACHED TO EACH OTHER BY WIRES. THE ONLY WIRES YOU'LL NEED TO DISCONNECT ARE THE ONES ATTACHED TO THE CORD WINDER ASSEMBLY. THEY JUST PULL OFF, NO TOOLS ARE NEEDED.
QUITE FRANKLY THIS IS A ROYAL PAIN AND YOU'LL PROBABLY WISH YOU TOOK IT TO A REPAIR (AERUS/ELECTROLUX) SHOP. IF YOU DECIDE TO DO IT YOUR SELF TAKE PICTURES OF EVERY STEP...'CAUSE YA GOTTA PUT IT ALL BACK TOGETHER.
GOOD LUCK!
Sep 08, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Automatic cord return
if it is anything like an electrolux there is a coiled spring inside that free wheels around a hub. pulling the cord too far out makes the spring slip on the free spinning hub. you may need to take apart the vac and rewind the spring.
Aug 28, 2007 | Panasonic MC-V9644 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
130 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
