Question about Dryers
When I push the button to turn on my Kenmore Series 70 dryer, nothing happens. What could be the problem and would I be able to fix it?
  • 1,531 Answers
Make sure to have the unit unplugged.
You will need to check the thermal fuses on the dryer.they are normally located near the heating element.If you have a volt meter you will need to check the continuity of all the thermal fuses ad if you find one that has not got any continuity replace it.
I do have a picture of the locations of the thermal fuses for some dryer in my tips.To test the door switch then you will need to remove the wires from the switch and test it the same way when you push the switch in by hand the meter should have a tone or read zero this is good if there is no tone or does not read zero then it is bad.
Also make sure the unit has enough power to it.
Thanks for choosing fixya i hope this will solve your problem
Posted on Mar 13, 2011
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
localwonder
  • 6784 Answers
SOURCE: kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Posted on Apr 26, 2009
  • 1122 Answers
SOURCE: Kenmore 70 series dryer doesn't turn
your dryer motor has just gone bad,it is no longer strong enough to turn over-sorry-mike
Posted on May 05, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore 70 series gas dryer - does not start when ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 22, 2010
heatman101
  • 43501 Answers
SOURCE: Have a Kenmore 70 Series,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 19, 2010
Kenmore 70 Series Electric Dryer will not start
It sounds like the hi-limit thermostate and/or the thermal cut-off is what is causing your dryer to shut down. Basically it's over heating. You should replace these two items togeather. Also the thermal cut-off will be triggered by a grounded out heating element. Here is a diagram of where these items are located. hope this helps
Figure W-6: Dryer Rear Access
Feb 27, 2012 | Dryers
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
Have a Kenmore 70 Series, Heavy Duty Dryer. Push the on button to start, nothing happens.
heatman101
Sep 19, 2010 | Kenmore 700 6972 Dryer
I have an older Kenmore 70 series dryer. When I push the start button nothing happens. I know its not the electrical outlet.
Your thermal fuse is bad located behind access panel between fan and exhaust. Little white plastic fuse with 2 blue wires connected to it. Rate me if I helped you. Thanks and good luck!
Aug 26, 2010 | Kenmore Dryers
Timer running but nothing happens 70 series
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. THis is the most common problem.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 18, 2009 | Kenmore 63942 Dryer
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Kenmore dryer series 70 won't turn on
Oct 26, 2008 | Kenmore 63942 Dryer
Kenmore 80 series dryer, won't turn on
Thanks for the question When you push the start button was thera hum if there is a hum when you push start you need a new motor THanks for the question The appliance doc
Jul 18, 2008 | Kenmore 63942 Dryer
Dryers Logo
267 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
