Question about MSI X340-021US Notebook
Hi, I need replace demaged screen. How do I do that, there is no screews on bazel. Thank you
  • 384 Answers
Hello There and Welcome to FixYa!
This is a very serious hardware replacement procedure and should be done by highly trained (brand) technicians with all the necessary tools and equipment to avoid any possible further damage and the like.
I am strongly recommending that you contact their helpdesk over the phone for more options and guidelines :
MSI Support
I hope this helps, Thank you for using FixYa.
Posted on Mar 13, 2011
I have a Dell Inspiron 2200 and need to replace the motherboard....how do i disassemble the laptop to get to the system board?
if you are now a computer technician, it is advisable to take your laptop to one to avoid demage of some components. Anyway, carefully open the laptop disconnecting the screen, remove your key pad and unskoll the motherboard to be replace. replace and carefully transfer component ensuring none is demage
Sep 28, 2010 | Dell Inspiron 2200 Notebook
I have a slight yellowing in the center of my screen. We recently replaced the map, and have tried adjusting all picture settings but the yellow patch remains. It's a Sony Grand Wega, by the way.
Don't know if the DLP tvs have a Deguassing coil,inside it bazel frame.Take ur tv aparts check,see if u have big coil rapping with ectrical tapes fit inside ur bazel frame of ur tv.If yes,the componnents parts that make the coil work it dead.This coil demagnictize for the tv tube first turn.All regular small CRT tube tvs '30 inches and down have this dequassing coil inside it bazel frame.
Apr 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The camera asked to format the card. We selected yes, and the display screen said processing. It has been processing for 45 minutes. What do we do??
Hi friend,
You need to format the card. because you card is not working properly..may be it is demage....you need to change your memory card otherwise your camera will demage...
Dec 20, 2009 | Vivitar ViviCam 3710 Digital Camera
My cat walked across my computer and now I can barely read the script on my screen.
There is a inverter which sits below the lcd.Chances are this is unpluged and not broken.Remove all power source from the computer.On the face of the lcd is a bazel .You will need to remove the plastic caps that cover the screws.When you remove them put them in a safe spot as you will need to replace them once you are finished.Remove the screws gently pry the bazel from the lcd careful not to break it.Below the lcd is a small circuit board called a inverter board chech the cable it might have poped out.
Good luck
Oct 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
How do you tighten the hinges for a gateway 7324 laptop? The cover has a few inches of play and sometimes the screen flickers.Is it repairable or must the hinges be replaced?
Remember before you do any work to remove the battery and the power supply.You will have to remove the Lcd Bazel.There should be some rubber covers over the screws on the bazel.Remove and put them in a safe place as you will have to replace them.Once you have removed the screws use your finger to gently pry away the bazel.Look towards the base you will see the screws tighten them and this should take care of it.
good luck
Sep 15, 2009 | Gateway Computers & Internet
Cracked screen
www.ebay.com has been a great source of computer parts for me.
May 15, 2009 | Mirus Notebook
Replacing control board
There are two screews onder the shield. You need to get level with the shield to see them. Remove the two screews and it should come off no problem. Now to get in to the controll panel you have to pull the oven out and there are two screews on the back in both top corners to get in side to the control board. Good luck
Dec 16, 2008 | Maytag MER5775Q Electric Kitchen Range
I am trying to replace the control board on a maytag mer5755qaq and need to remove the heat/visor shield. How do I do this? Please help!
Dec 16, 2008 | Kitchen Ranges
Crack screen
HI fllow the step plz. open the uper body > open 4 screew > pick the protection plate > u see a jeck of display > plz open with carefully > place a new display > push the jeck tightly > place the protiton plate > put the screew > tight carefully > place the body. keep voteing THANKS.
Mar 22, 2008 | Nokia 5300 Grey Cellular Phone
MSI X340-021US Notebook Logo
62 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
