Question about Electrolux 504199 Dishwasher
Where does the water hose hook up at on the electrolux dishwasher
    Scholar:
  • 158 Answers
Posted on Mar 13, 2011
  • 338 Answers
SOURCE: no water is coming to dishwasher
Check and see if you have 120 comming to the fill valve. if you do the start to loosen the hose you connected to make sure the valve actually opened when you turned the water back on
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: Dishwasher full of water
Check all areas stated below to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Posted on Jun 18, 2009
SOURCE: electrolux dishwasher water left in the bottom
make sure your drain hose behind the unit is not bent or kinked
Posted on Apr 12, 2010
heatman101
  • 43501 Answers
SOURCE: My dishwasher doesn't fill with water even though
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Aug 23, 2010
SOURCE: how to open and clean the inlet water hose filter of Electrolux Dishwasher ESF 6150
all u need to do is hit it with a hammer
Posted on Nov 27, 2011
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
Water in bottom of dishwasher
Good Afternoon Friend,
I understand you have water in the bottom of your Electrolux dishwasher. First, if your appliance is hooked up to a food waste disposer, make sure the disposer is empty. Secondly, check to see if the knockout plug has been removed from inside the food waste disposer inlet. Thirdly, check to see if drain hose is kinked. Lastly, make sure cycle is complete, not in a pause. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If f Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Electrolux Dishwashers
I would like to empty the drip pan and would like instructions on how to access it
The best way to get rid of the water would be to take the dishwasher out from under the ktichen bench after taking off mains plug and disconnecting hoses. Then tilt it on its side to get the water out on the kitchen floor. If there is a leakage which caused the water to collect then find source and fix it. Usually pump hose clamps, broken hoses or even the door seal.
If you need operating manual it can be down loaded from
http://www.manualrepubliccdn.com/pdf/electrolux/electrolux-eidw6105gb-owner-s-manual.pdf
it might be helpful to find details if you can provide the Product Number of the dishwasher. This should be listed on the right side top of the door.
Apr 17, 2014 | Electrolux EIDW6105GB 24 in Builtin...
Electrolux professional series not pumping water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
Standing water in model FDB1050RESO frigidaire electrolux dishwasher 2005 model
I see that you have standing water in your Frigidaire dishwasher, model# FDB105RES. I would suggest trying the troubleshooting tips below:
• If your appliance is hooked up to a food waste disposer, make sure the disposer is empty.
• Check to see if the knockout plug has been removed from inside the food waste disposer inlet.
• Check to see if the drain hose is kinked.
• Make sure the cycle is complete and not in a pause mode.
If you are still having trouble with your dishwasher not draining, I recommend contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
No water entering dishwasher electrolux 602
First is water coming into the location and is the valve to the dishwasher open? Next check if the intake hose is bent or squashed. Release the kink blocking water flow.
There is a filter in the intake hose that can get blocked by debris. Turn off the water (at the supply valve) then disconnect the intake hose. Clean the filter. Reconnect the hose and turn the water back on. Check for leaks.
The manual for the unit is available here: http://kitchen.manualsonline.com/manuals/mfg/electrolux/esi_602.html .
I hope this helps.
Feb 21, 2011 | Electrolux 23 in. ESI602 Free-standing...
Electrolux dishwasher water left in the bottom
Apr 12, 2010 | Dishwashers
HI i have an electrolux dishlex dishwsher that is brand new and just installed. Ive used it a few times an dhave noticed that there is water at the bottom of the dishwasher, thats not draining, I thin
there is always a little water in all dishwashers. Sounds like to me that you may have a kinked drain hose or maybe the way you have hooked the drain up. The drain hose should go to a vacuum break that is mounted on the sink flange and then another hose goes to the disposal. If you have the hose hooked directly to the disposal you may be getting water back from the sink to the dw. raise the hose up as high as possible and attach under the sink so there is a high loop in your hose so water cannot drain back from the sink
May 29, 2009 | Dishwashers
Electrolux 504199 Dishwasher Logo
154 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
