Question about RCA L40HD33D 40 in. LCD HDTV
I have an RCA L40HD33 model .... Tv has picture but no sound... the dvd player works fine both picture and sound.....Help??
I have lhd4033d rca tv dvd combo. was having sensor problems with my remote. bought a new one. still not working. took front screen off to find out that I had two wires broken. now the problem is solved. tv works fine.
Posted on Oct 06, 2011
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
No picture but sound on DVD player
hi..it maybe a RCA connection problem..it's better that
you don't remove the audio, try to re insert the video RCA
its color yellow...look also for yellow RCA port on the TV and connect the
RCA from your player...if still does not work why not use a new RCA jacks..
hope this help...please rate and vote..thanks
Feb 19, 2011 | RCA DRC6100N DVD Player/VCR
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
Samsung dvd-v6800. dvd works fine but the video has sound but no picture can you help?
It depends on what video inputs you use.If you using RCA out on the player you must use RCA in on your TV,same with super video which is over rated.Output is fixed on most DVD players,on tv's check on the back and make sure the inputs match the ones on the player.
Jan 03, 2009 | Samsung DVD-V4600 DVD Player/VCR
My RCA TV Model F27442 has no picture
is it snow on screen? if so tuner  problems. rca had recall on tuners on some models bad solder connections in tuner
Dec 03, 2008 | RCA 32V420T 32" TV
I have a 32 inch sharp tv and it has been working fine, but i just went to watch a dvd and got sound from the dvd but a green, disjointed pattern instead of pictures. i switched dvds and it was the same...
there is a possibility that you have switched the RCA cables for the right port, the color patterns happen if your plug the component RCA ( Y Pb Pr) on a diff port. their usually color coded so please double check that to.
e733778.jpg if not, please let us know what is the model number of the TV and we will find what can be done in the TV.
Aug 10, 2008 | Televison & Video
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Dec 21, 2007 | Televison & Video
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
RCA L40HD33D 40 in. LCD HDTV Logo
156 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
