Question about Samsung RS2556 Side by Side Refrigerator
Samsung RS2556BB display is flashing on 34 degrees for refrigerator side; does not seem cool-- what could be problem
Power went out yesterday now the display on the door will not work and neither side is cold
Posted on Aug 10, 2011
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 13, 2011
Msd2756de fridge side wont cool
all of the above solutions are correct evaporator fan going bad causing the ice to build up defrost timer getting stuck or heating element for defrost not working...good luck
Mar 16, 2014 | Maytag MSD2756G Side by Side Refrigerator
Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Mar 31, 2009 | Samsung RS2578BB Side by Side Refrigerator
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Dec 01, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Temperture rising in refrigerator,not cooling. samsung rs2556bb
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Samsung Refrigerators
Refrigerator not cooling
Open the panel in the freezer, and take a hair dryer to the frozen coil.
May 13, 2008 | Refrigerators
Samsung RS2556 Side by Side Refrigerator Logo
990 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
