Question about Watches
I have a Centrios Atomic Wall Clock, Model 631-8159. I had to replace the batteries and now I am not able to reset the time, month, date and day. All that is correct is the temperature. I selected jewelry as wall clocks is not an option.
SOURCE: Sharp Atomic Clock
I have a sharp atomic clock that once set for the exact time, after a day loses 3 hours.
Posted on Sep 18, 2008
SOURCE: repair of battery-operated wall clock
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
Posted on Sep 20, 2008
SOURCE: zeon tech clock manual
Hi - Zeon have the instructions for their clocks and watches in the Download section of their website http://www.zeonltd.co.uk/ Just type in the model number e.g. CE1648 (analogue-digital alarm clock)
Posted on Dec 19, 2009
escapement
  • 2334 Answers
SOURCE: setting time zone for atomic clock
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please..
Posted on Mar 29, 2010
  • 16 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
I need G-Force giant atomic clock instructions. There is no model number on the clock. I put in new batteries, and it sets to 1-1 month and day and 12:00 time.
See if these are the instructions..
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.lacrossetechnology.com/media/catalog/product/5/1/515-1316.pdf&ved=0ahUKEwi20reMi4jWAhUh24MKHcfpBeEQFggsMAI&usg=AFQjCNEsCBnwTraroE9N7qRdGqTzKjh3Fw
Sep 03, 2017 | The Watches
Cannot adjust time on ohe atomic clock
Let it adjust itself, usually at next transmission time WWV in Hawaii reset several times a day every four hours or so.Thats my experience.
May 13, 2017 | ATOMIC Watches
I replaced the battery. The watch started time from Jan. 1
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Sep 27, 2013 | Casio GW330A G Shock Solar Atomic Watch
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
Set time zone on centrios atomic clock
1. In the normal time mode, Press MODE key to enter the alarm time mode .
2 Press SET key to change the time zone, P is pacific, m is mountain c is central and e is eastern.
Nov 26, 2010 | Watches
I have a Skyscan Atomic Clock - does anyone know how to set this clock for the right time zone and day, etc?
Hello.<br /> Thank you for contacting FixYa.<br /> You should be able to find instructions here!<br /> <a href="http://www.atomicclocksstore.com/skyscan-atomic-clock-model-81690-manual">http://www.atomicclocksstore.com/skyscan-atomic-clock-model-81690-manual</a><br /> Best regards.
Aug 25, 2010 | Watches
I have an antique Waterbury wall clock, how do I change the month, day and date
INFO:
As long as it is not in the date advance cycle some where around midnight you should simply be able to reach around to the back of the disk and rotate the dial.
DISCLAMER:
Tip provided sight unseen.
Clock not fully described.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Mar 20, 2010 | Watches
Sharp Atomic Clock
Sep 02, 2008 | Watches
Can't receive atomic signal
You can get it serviced at www.casiosalesandservice.com or call them toll free 877.659.0761
Jun 03, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
60 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
