Question about Protron PLTV3250 32 in. LCD Television
The power is not working on the actual TV. We have checked all the cables & unplugged & re-plugged in everything! The little light isn't on for the power (lower right hand corner) Any suggestions? thanks!! Shirley
    Master:
  • 691 Answers
Yes bad power supply, if you take out you will probably see bad capacitors on the PS board. Replace and set will come on
Posted on Mar 13, 2011
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
I unplugged the little cables in the F_PANEL to the right bottom in my GIGABYTE GA-G41M-COMBO motherboard and the CPU is working after i reconnected them the but nothing appears on the monitor i hear the...
The problem most likely isn't with your f_panel your motherboard should have a manual that tells you how to plug everything into your f_panel correctly.
Ensure that there are no empty power connections on your motherboard. You board may not be powering its video component. If you have a graphics card, ensure if it requires a power connect that it is properly plugged in.
If this doesn't work I suggest your return your motherboard as it is not functioning properly.
Jun 17, 2011 | Gigabyte GA-G41M-Combo Motherboard
29agm2 how to access the servise menu
Hello
Check these proceedings and find out which porocess works with your Sharp TV.
* Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* While holding the above buttons, plug in the TV.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
Mar 22, 2011 | Sharp 29AGM2 29" TV
There is a only a vague picture on the screen. There is sound but no picture. And the problem is not the setup/tv menu. What is the problem. The TV is only one year old.
As a preliminary step, try unplugging the power cable and then push the power button continuously for 10 seconds (this should drain the flea power from the capacitors inside your monitor). Now plug the power cable back and turn on the TV to check.
This can happen when the back light / the back light circuitry is not working which actually lights the LCD panel in the monitor. Please check for the warranty for this product if so immediately contact RCA tech support. If the monitor is out of warranty then its time you approached a local TV / Monitor repair technician.
Dec 22, 2010 | RCA L26HD35D TV
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Protron PLTV3250 32 in. LCD Television Logo
20 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
