Question about Husqvarna Sewing Machines
Husqvarna 500 Computer sewing machine was sewing fine and then it just started running very fast all by its self. I unplugged and waited about 15 minutes removed the bobbin and thread, turned back on and it runs by itself with the foot pedal unattached. Please, can someone tell me what to do, or what may be wrong. Thanks Louise T Duncan, OK
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 8 Answers
SOURCE: Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Posted on Nov 17, 2008
kent581
  • 87 Answers
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Posted on Mar 18, 2009
  • 192 Answers
SOURCE: bobbin holder won't stay put
If the bobbin case/holder is trying to lift up and the thread is staying partly around it, your bobbin case may have turned part way.
Remove the needle plate and the bobbin case. The outer edges of the bobbin case should be very smooth. I suspect you may see a needle hole in the flat area that was under the foot. If so, you will probably wish to take it to your dealer and show them. They may smooth it or recommend replacing it. When the bobbin case is placed back into the hook cup that it sets in, the retainer at the 11 o'clock position on it should only allow the case to lift up about 0.8 to 1mm at the most. If it will lift up more than this, press down firmly on the retainer and move it closer to the bobbin case. You must have enough room for the thread to pass between the retainer and the bobbin case, but too much clearance will allow the bobbin case to turn in the machine and it will be damaged by the needle.
Posted on Apr 09, 2009
  • 30 Answers
SOURCE: I own a husqvarna emerald 116 sewing machine, and
is the bobbin thread in correctly( meaning is the bobbin thread in the lower tension) if it is and the top thread is in correctly and make sure the feeddogs are in the up position if all of these factors are alright then it will have to go to a local dealer to get taken care of
Posted on Oct 28, 2009
I need to wind thread the bobbin for a husqvarna viking 500 computer sewing machine
Download your manual here: http://www.pdfsdocuments.com/husqvarna-viking-500-computer-sewing-machine-manual.pdf
Feb 02, 2016 | Husqvarna Sewing Machines
Husqvarna 500 sewing machine won't turn on
yes, it's possible. also could be the on/off switch, or the power cord.
Jan 24, 2014 | Husqvarna Sewing Machines
My Viking 500 suddenly stopped running. The machine comes on and will sew and then won't start. Stitches are fine. The computer shows something wrong with the foot. The symbol for the buttonho
The foot pedal has nothing to do with this. You machine is telling you that you have the wrong presser foot on the machine for what you are trying to do.
Do you have your manual? Mine tells me what foot goes with which stitch.
Aug 31, 2012 | Husqvarna Sewing Machines
Just purchased a Kenmore 19106 Sewing Machine for my daughter's 16th birthday. It's her first one and she was excited to get it. I don't know anything about sewing machines and how they operate. My...
Take it back. This should not be happening.
If you can, bump up a model.
You can find reviews of sewing machines at patternreview.com - note how long the reviewer has used the machine before they wrote the review.
Feb 20, 2010 | Kenmore Sewing Machines
Need to get a copy of Husqvarna viking 500 computer sewing machine
Go to Husqvarna Vikings web site and use the dealer locator. Put in your Zip code and your nearest dealer will come up. You should be able to order it over the phone with a credit card.
Oct 08, 2009 | Husqvarna Sewing Machines
My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Mar 14, 2009 | Husqvarna Viking 1
Sewing Machines Logo
73 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
