Question about Frigidaire ATF6000ES Front Load Washer
We have a Frigidaire ATF6700FS1 Front Load Washer that sometimes has water in the tub long after we finish washing, like 3 days later when we want to wash again, but didn't have the water when we washed the last time. Why?
  • Frigidaire Master
  • 8,220 Answers
The mount a coin catching cup inside the tub to pump hose. Perhaps yall need to remove and inspect for objects.We have a Frigidaire ATF6700FS1 Front Load Washer - themobilian_1859.jpg
Affinity service manual
Posted on Mar 13, 2011
Model ATF6700FS1 Affinity was squeaking and tub was hard to turn; now its not turning at all.
Hi Ikolacsky - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 09, 2013 | Frigidaire ATF6000ES Front Load Washer
Problem with water in tub of front load washer
Two possibilities here - bad valve, not closing completely when off or you have a bad control that is sending residual voltage to the valve when it is off. Contact a service technician.
Aug 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
The front loading washer (LTF6000ES1) will not complete a washing cycle. It leaves water in the tub and doesn't finish.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 23, 2011 | Frigidaire Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer SMELLS!!!!
your inner tub needs to be removed and the outer tub including the outside of the inner tub needs to be cleaned of all the sludgy soap, fabric softener,etc. that has built up in between the tubs,along with the drain tube at the bottom,you might try bleach as a stop gap,but sooner or later you are going to have to clean this out the hard way,its not fun
Mar 09, 2010 | Washing Machines
When you open the door there is an odor that come from inside the wash tub
this is due to the build up of scum in the washer pipes the best thing to clean it out with is bleach ,,,do a cold/hot water wash with nothing in the washer only a strong mix of bleach, when the wash has finished do another cold/hot wash again this time with only water in the washer to flush out any bleach left in the washer then leave the door open a little when you have finished your washing from then on,this should kill of any more nasty smells
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Washer won't drain water
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Jun 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
607 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
