I HAVE A SHARP AR-BC320 AND THE TRANSFER BELT UNIT WILL NO CONNECT TO THE PORT. WHAT IS THE EASIEST WAY TO GET IN THERE TO MAKE SURE IS CONNECTS.
    Sergeant:
    Champion:
  • Office Equip... Expert
  • 345 Answers
Remove the fuser unit for easier access. There is a big retaining knob underneath the fuser that you need to unscrew to get it out of there. Other than that remove all of the D.V. units and drums to see if that helps you. Good luck.
Posted on Mar 13, 2011
Sharp arbc 320 error code tk how could i resset it
The counter for your mylar transfer belt has gone past 100,000. The belt has reached the end of its' rated life. You could clear the counter with Sim 24-4 but your copy and print quality will change. Eventually your belt will wear out, develop cracks and then split. There are rebuild kits for the belt unit or you can buy a whole new unit. Also the waste toner tank attached to your belt frame is probably filled up by now.
Aug 02, 2010 | Sharp AR-BC320 All-In-One Led Printer
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
What is code F1-03 mean for a Sharp AR-BC320?
Check the sorter whether its well connected and check its motors and sensors.
Oct 22, 2009 | Sharp MX-2300N Color Copier
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Jul 17, 2009 | Sharp Office Equipment & Supplies
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
89 people viewed this question
jasbo
jasbo
