Question about Maytag Atlantis MDG6400AW Gas Dryer
My Maytag MDG640AWW gas dryer timer does not advance and auto shut off. What part number do I need to replace this part?
    President:
  • 3,074 Answers
My best guess is a restricted vent, disconnect dryer vent hose and run dryer, it should work if not then there a few other things, here is a link that will help you:
http://www.hometips.com/repair-fix/laundry-dryer-timer.html
Posted on Mar 13, 2011
Maytag Dryer MDE6400AYW. Dries clothing but does not shut off in Auto Mode. Tried Timer mode but the knob does not advance on its own and dryer does not shut off in that mode either. Replace Timer?
Some of them timer can be oiled, (just a little zoom oil no wd-40) if it is real hard to turn, the knob can become cracked and the timer motor itself it may not have enough ump to move the gears and sometimes oiling the timer and moving it around many times loosens em up.
Jan 11, 2017 | Maytag Dryers
Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Dec 12, 2007 | Dryers
Maytag gas dryer lsg 7800 just replaced gas valve dryer now heats but timer does not advance or shut off
Ok that machine was built back in 89, good chance the timer is out. If you really like that machine I would get as many replacement parts I could find for it. They are better machines than the ones they are selling on today's market.
Apr 18, 2014 | Dryers
Dryer doesnt work on settings
I have repaired (2) gas Maytag dryers that appeared to have timer issues. In both cases, it wasn't the timer, but the temperature sensors. In both cases, I replaced them and the dryers operated A-OK. The sensors signal the timer to advance. One sensor is located just beyond the flame where the gas is burning, the other just before the squirrel cage blower. In addition, there are (2) electrical coils located in front of the gas igniter assembly. If replacing the temperature sensors doesn't fix the issue, then replace the coils.
Apr 06, 2014 | Maytag Dryers
Comercial maytag dryer will not shut off. tried replacing timer. heats up but will not shut offf
When a dryer heats but the timer does not advance especially on the auto. dry setting (not timed dry) the problem is usually always a airflow problem. What needs to be checked is for lint build up in the blower housing, a blocked or restricted. Also on Maytag dryers a problem sometimes is that the blower wheel drive hub where it connects to the motor is stripped so the blower wheel cant move air,typically if that is the case a rumbling will be heard when dryer starts and once again when the dryer stops a rumblimng noise will be heard.
GENE
Sep 23, 2011 | Maytag Dryers
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Automatic drying doesn't shut off
its the switch problem its got tripped internally so its not getting shut off.if the switch would have tripped to the opposite side that the dryer would have nit turned ON. so the switch needs to be opened the tripper needs to be replaced.easy job but very technical. thanks
Feb 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
98 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
