Question about Baby Lock Sewing Machines
I have a Baby Lock pro line and can not get it to sew. I am trying to put in a new bobbin color and it looks fine and feels fine, but when I try to sew it just locks up. Thanks. K
  • Baby Lock Master
  • 1,564 Answers
Hi Gypsy:
Take a look at your sewing manual for your Pro Line. I suspect you have your bobbin in upside down. Most machines require the thread to spool off the bobbin in a certain direction.
Posted on Mar 13, 2011
My Baby Lock A line Series sewing machine just started bogging down real bad?
how is it boggin down? have you tried a new needle-one for the fabric being sewed
make sure the power cord is plugged in snuggly
clean under the needle plate and in the bobbin area for lint or loose threads
Apr 30, 2016 | Baby Lock Sewing Machines
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Why does the bobbin case on my Baby Lock Elegante seize and pop up?
Sounds like you have a burr. Examine both the case and the bobbins for burrs. (use your fingernail... feel for thing that catch your nail) File them off carefully with fine grit sand paper.
Burrs can happen when a needle bends and breaks... stabbing the wrong area... sometimes it's manufacturer defect in the plastic bobbins.
Nov 17, 2012 | Sewing Machines
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
I am trying to sew a baby blanket, but when I start the thread keeps binding up. I am new to sewing and asked a friend, they said it was a bobbin problem so I change it. I started sewing again and problem...
To:
By ladydiane56 on Jul 10, 2011
I am trying to sew a baby blanket, but when I start the thread keeps binding up. I am new to sewing and asked a friend, they said it was a bobbin problem so I change it. I started sewing again and problem still there. Need some advise. Thanks
It sounds like the tension between the top and bottom threads isn't balanced. With the machine threaded, pull both threads towards you and feel if one is tighter than the other and if so, adjust the tension. Top thread adjusts with the tension knob on the front of the machine, bottom thread adjusts where you load the bobbin. Could also be that the bobbin is sitting in the shuttle the wrong way. Have it sitting in the shuttle so that as you look at the open shuttle and pull the thread, the bobbin turns clockwise. Hope this helps.
Jul 10, 2011 | Brother Sewing Machines
Bobbin not even
buckmanfamil....I use my finger to keep tension on thread when i fill my bobbin.i also pusu thread slightly up & dwn to even it out on bobbin.works for mine ! I luv my Baby Lock !!
May 29, 2009 | Baby Lock Sewing Machines
Sewing Machines Logo
136 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
