File\minit\system32\Kdcom.dll could not be loaded.The error code is 4. The above massage is showing when I try to restore my Acer Aspire One.I am not able to run my window XP. Please help me.
    Sergeant:
    Champion:
  • 239 Answers
It sounds like this file is corrupt you need to download a fresh copy and install it.
I would suggest trying to open your laptop in safe mode. While you are booting continually tap F8 and you should get a different menu. You need to select start in safe mode with networking. Follow the instructions to open it as an administrator.
When you have the system open use the internet to download a fresh copy of Kdcom.dll from here
http://www.dll-files.com/kdcom.zip?0WMmXCVMeO
Unzip the file to the same path as you show in your error message and overwrite the old copy of Kdcom.dll
Now restart your machine and hopefully this will have solved your problem.
Posted on Mar 13, 2011
\windows\system32\kdcom.dll Missing or corrupt Kernel debugger
Try tapping F8 at bootup to enter safe mode, read your manual to see if you have a recovery partition on your HDD. You didn't post the model so I have no clue.
If you can enter safe mode you need to try system restore, not last good know configuration.
If you see last know config on your screen, then you should also see safe mode.
So you need to run in safe mode, and run system restore, or run the recovery mode if you have a recovery partition on the HDD.
If none of these work, then you only have three options, go to Avira.com, download the rescue disk, burn it to a CD and run it in DOS, this is before windows boots. Now if malware corrupted the DLL, Avira will kill it, but there is a chance it can't clean it and will destroy the files,DLL, and windows won't boot. So now you have to do below.
The other option is you need to download windows, what ever version you have, if you have win 7 home 32bit, then you have to download it, and burn it to a DVD. Then try a repair, if a repair does not work then you need to reinstall windows, and then install all the drivers like, (chipset, video, sound, lan, wifi)
This option, you can contact Acer and see if they have a recovery disk for you.
Good luck.
Apr 01, 2013 | Computers & Internet
How to fix \minint\system32\kdcom file cannot load error 4 Emachine
Download this file to your computer and burn it to a CD:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
If you don't have an app that can easily burn .iso files to a CD then get this awesome little FREE app and install it:
http://www.majorgeeks.com/downloadget.php?id=4870&file=9&evp=0636b68877cb69b15faa3374cb1dcd89
The Bootable CD you burn should fix your computer. It's really easy to use. Just follow the instructions from page 15 to page 33 in this pdf:
http://support.kaspersky.com/downloads/guides/kasp10.0_rescuedisk_en.pdf
You basically want to update the virus definitions and select all of the checkable boxes to scan and run the scan and then allow it to delete or quarantine the bad files.
Sep 01, 2012 | E-Machines eMachines Desktop PC
My acer one has no cd rom and has an error report windows could not start because the following file is missing or corrupt <window root>\system32\hal.dll please re-install copy of the above file
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Aug 05, 2011 | Acer Aspire One PC Notebook
What does minint\system 32\kdcom.dll error code 4 mean It came up when I tried to do a system recovery on my laptop. Now all I get is a virus running scans for viruses..... How can I fix this?
This is a virus, you have to run your virus program in safe mode. As the system starts to boot up, hit the F8 key and select "Safe Mode". Once the system boots into safe mode run your antivirus software and do a full scan. Verify your system is virus free. Then follow these steps...
Boot From Disk
Insert your Windows XP/Vista disc and boot from it. If you don't know how to boot from a disc, during the your splash there is, hopefully, a legend that pop's up briefly (most often at the top right of the screen but not always). It will usually say two things: SETUP and BOOT MANAGER. Next to those will be the keys to press to start either. Press the one for the BOOT MANAGER. Unfortunately its not the same for every computer, but usually its something like F10 or F12.
Enter Repair
So once your fully booted into the XP/Vista disc, you'll have three options. Choose the REPAIR option by pressing R.
Select Installation
Recovery Console is command based. You'll be asked for the drive that your Windows is installed on. Typically its "1" unless you have multiple installs.
CD Drive Letter
When you get to the prompt C:\WINDOWS>, you will need to figure one thing out before moving on and that's what your CD drive letter is. Try typing "D:" without quotes. When D:\> comes up, type "DIR" without quotes. If a list comes up that has "I386" in it, then remember your drive letter is "D." If not then replace "D" in the above directions with "E."
The Repair
Once you have found your disc drive letter, follow each of the following commands line by line.
C:\WINDOWS\>CD system32
this will move you to the system32 folder
C:\WINDOWS\system32>COPY kdcom.dll C:\
this copy is a backup in case things don't work
C:\WINDOWS\system32>DEL kdcom.dll
this will delete the original not the backup
C:\WINDOWS\system32>COPY D:\I386\kdcom.dl_
replace the D if you have to with whatever your disc drive letter was above. the kdcom.dl_ is not a typo either.
C:\WINDOWS\system32>REN kdcom.dl_ kdcom.dll
renames kdcom.dl_ you copied to kdcom.dll
C:\WINDOWS\system32>EXIT
reboots your computer.
Jun 21, 2011 | Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Help on reformating pc!!!
Use different CD installer or burn your present WindowsXP to another disc. Your files might have been corrupted due to poor disk surface of your Windows Installer.
Jan 21, 2010 | Acer Aspire T310 PC Desktop
System unable to boot
Why r u trying to search a single file like tat???Ur computer's system file is missing,,best option --format the harddrive and reinstall the OS,,backup all ur data before doing that
May 12, 2009 | Acer Aspire One N270 Notebook
Tosiba laptop could not start not even with safe mode.
The error message refer to system files it cannot load dur to either corrupted or missing files.
You can try to do a repair with your Windows CD install disk and if this does not work you will need to reinstall Windows again together with any drivers that Windows didn't install and your programs.
Note you will lose you data in this process, hoped you backed up your files.
Mar 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Image.dll is missing
Download the file from here
Save it to the desktop.
extract the file to your system directory.
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000),
C:\Windows\System32 (Windows XP/Vista)
Once the file has been extracted to the system folder,
  1. Press Start and select Run
  2. Type CMD and press Enter
  3. Type regsvr32 "filename".dll and press Enter
If error occurs In step # 3 above Type regsvr32 "file location/file name" and press enter
Feb 20, 2009 | Acer Aspire 5610-4648 Notebook
\system32\hal.dll. MISSING FILE
YOU NEED TO DOWN LOAD THIS PROGRAM FROM MICROSOFT.
WWW.WINDRIVERS.COM/HAL.DLL
OR
WWW.WINDRIVERS.COM/SYSTEM32/HAL.DLL
ONLINE ADDRESS BAR: WINDOW DRIVERS FOR SYSTEM32\HAL.DLL
OR FIND THE FILE IN THE ORIGINAL SOFTWARE YOU INSTALLED THE WINDOWS VERSION ONTO THE SYSTEM
ROD
Feb 12, 2009 | Acer Aspire 5000 Notebook
Computers & Internet Logo
586 people viewed this question
David Payne
David Payne
