Question about Kohler Plumbing
Kohler K305-K valve with Diverter, diverter will not stay in & there is almost no water flow. No sign of any blockage inside of valve.
5 Suggested Answers
  • 10865 Answers
SOURCE: Greetings! My Kohler kitchen faucet
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Posted on Jan 21, 2009
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
  • 88 Answers
SOURCE: Kohler purist shower and tub diverter valve has
washer on back of diverter stem needs replacing
Posted on Aug 25, 2009
bearsfan7538
  • 119 Answers
SOURCE: Trying to fix leak on kohler fairfax kitchen
You need to remove handle and cartridge and spout should come off to replace the rest very common leak
Posted on Nov 15, 2009
Water won't stay on
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 25, 2013 | Kohler K-14677-BN Loure bath- or...
Error code 52
Diverter Valve Fault
Remove Diverter Valve (Down near the Pump Under Bowl) Check for Blockages or broken hinge mechanism
Check resistance of wax solenoid on diverter Valve
Resistance Should be between 0.7 - 2.5kohm
POWER OFF PLUG OUT
May 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
I've taken the spout off and can see the diverter but I can't get it out of there. How do you get it out?
I have a K-R10430. I was having issues with the hand spray - poor water pressure. Kholer sent out a new diverter. After shutting off watner, when you remove the small screw in the back of the Spout, pull the spout off. Put a paper towel into the body to soak up excess water inside body. Then you need a small screw driver or small flat item to fit inside one side of the retaining ring near the opening, there is a space where you can fit something behind and carefully move the retaining ring out. Pull out with needle nose pliers then pull the diverter out with needle nose pliers. Insert new diverter with teeth facing up and push down. Insert retaining ring and make sure it slips into same **** in wall of body.
Jul 11, 2010 | Kohler Model 10430: FortĀ® Single-control...
No running water from my shower
Check water lines to shower and make sure that there is no blockage or water cut off to it. Valve itself could be bad also or blockage inside it.
I f it is a tub & shower unit the diverter may be bad or stuck in place restricting water flow. Some are push button on the valve or a pull unit on tub spout to send water to shower head.
Cut water off and remove to inspect for reason not functioning correctly.
Remove shower head to inspect for blockage. The srceen may be stopped up for the shower head. Remove turn water on and see if any flow comes out shower arm.
May 19, 2010 | Home
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Worcester 24i combi when in shower hot water flicks on and off can hear gas igniting and extinguishing
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Aug 06, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
Greetings! My Kohler kitchen faucet model K-10416 with sprayer (16 months in use) is making noise when water is turned on in both hot and cold positions. Also, when sprayer is used water flow is not being...
Jan 20, 2009 | Plumbing
Plumbing Logo
117 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
