Question about Asko D1776 Stainless Steel Built-in Dishwasher
Asko D1996 Dishwasher - Tank fills with water but the "washing" cycle never starts. However, the heating element begins the work and with no water running over the heating element it smells like something is burning.
Rotu
  • 175 Answers
SOURCE: Asko D1796 will not start properly
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
Posted on Jan 13, 2007
  • 24 Answers
SOURCE: ASKO D3350 Dishwasher won't work.
possible failure of electronic board expensive to fix. May even be suprresion capacitor. A lot of brands used suppression caps on the ac input to filter out unwanted noise. When these blow they stink and some even arc but one thing is sure they cut the power to the rest of the dwasher may even throw out your power.Make sure it is switched off and unplugged before dismantling it.
Posted on Oct 08, 2008
SOURCE: strange odour from dishwasher.
There was a recall of this model for fire hazard - the recall is still in effect
Posted on Sep 04, 2009
  • 901 Answers
SOURCE: Asko D1996 dishwater does not turnon.
Check inside the machine for fuse or circuit breaker. Replace or reset. If repeats, you have to contact the service center.
Posted on Apr 15, 2010
  • 54 Answers
SOURCE: burning smell coming from dishwasher caustic to
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Posted on Apr 22, 2010
Asko d1996 circulating pump
A new circulating pump will be available on line from this site
Asko Dishwasher Circulation Pump 8801312
Aug 29, 2014 | Washing Machines
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
Our Asko 1885 Dishwasher is stuck in drying mode
Check if the other functions of the dishwasher are OK such us when filling, draining or the heating element heats up properly. The control board may have detected some errors and it is not proceeding. You may have to have the parts involved in the faulty function checked out such as the valves for the drain and the fill if your machine is not filling or draining properly or filters blocked. Check the heating element and inspect the assembly for burns especially on the relays. The machine may not be heating correctly that is why it is not finishing the cycle. If these parts checks out OK, you may want to have the control board checked out or replaced.
Oct 09, 2009 | Asko 24 in. 1885 Built-in Dishwasher
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Dishwasher pump motor stops
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Manydishwashers heat the wash and/or rinse water to a higher temperature,as the cycle calls for it. In these cycles, the dishwasher pauses afterit has filled with water, waiting for the water to reach the pre-settemperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • Onothers, the cycle can't continue until the water reaches the highertemperature. If you have this type of dishwasher and the water isn'tbeing heated (say, because of a problem with the heating element orthermostat), after the unit stops at the heating cycle, it nevercontinues. When you repair the heating-system problem, the "cycleproblem" is fixed too.
Timer Timersdon't often fail. But if every other part of the dishwasher seems to beworking properly and the timer knob seems to be stuck in oneplace--doing one function continuously--the timer may be at fault.Dishwasher timers can't be repaired. If yours is defective, replace it.
Dec 10, 2008 | GE Dishwashers
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko D1996 Stainless Steel Detergent Door Does Not Open
the pcb will need replacing,the dispenser gets its power from there.
Feb 28, 2008 | Asko D1776 Stainless Steel Built-in...
Jan 01, 2007 | Asko D1796FI Built-in Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
63 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
