Question about Huffy So Sweet Children's Bicycle
Noisy rear wheel - Huffy So Sweet Children's Bicycle
The chain may be dry and needs to be lubricated. For lubrication, use a very light oil. Don't put grease as it will likely to attract dirt that will stick to the chain and the rear cog, which will worsen your problem.
Posted on Mar 15, 2011
It is making a humming noise
Rear projection TV's have fans that can become noisy with age also the colour wheel motor also can become noisy. Replacing the fans should be easy and cheap, the colour wheel motor not so much.
Dec 24, 2014 | Samsung HLN5065W 50" Rear Projection...
Maytag mde3000ayw - this dryer makes a lot of scraping noise and squeaking. What could be the cause?
Hello there:
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Manydryers use rollers or wheels to support the clothes drum. When theserollers are worn, they can be noisy. You should replace the whole setof rollers at the same time. Idler pulley Dryershave a tension or idler pulley that keeps tension on the main drivebelt. When it's worn, it can be noisy. When that happens, don'tlubricate it. Just replace it. Glides Manydryers use nylon or plastic glides at the front of the clothes drum forsupport. When these are worn, they can be noisy. When that happens,replace them. Rear drum bearing Somedryers support the clothes drum in the rear with a center spindleinstead of rollers. The spindle may be a ball-and-socket type supportor a shaft through a sleeve. When the components are worn, they maysqueak, squeal, or rub. You can't repair them. Just replace them whenthey're worn. Blower wheel Yourdryer's blower wheel pulls air over the heat source, through theclothes drum, and past the thermostats, then pushes it out the exhaustduct. The blower wheel, which is usually plastic, may wear out overtime. But if it's noisy, it may simply be clogged with lint. Clean theblower and test to see if the dryer is still noisy. If it is, youprobably need to replace it.
Dec 25, 2009 | Dryers
Affinity front loader dryer. The drum is not
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it. Hope this helps
Dec 10, 2009 | Dryers
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Aug 18, 2009 | Maytag Dryers
Dryer has a squeaking noise. does it need to be
Change the belt and check all of the bearings for play. If any have too much slack replace them.
Jun 23, 2009 | Dryers
Dryer makes a squeaking noise
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
thanks and please do not forget to accept the solution
Apr 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Metallic squeaking from Amana Dryer
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Good luck.....
Mar 28, 2009 | Amana Dryers
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Mar 07, 2009 | GE Dryers
Noisy rear bearing?
Is isnt the rear end it would be very bad shaking and wouldnt last long because it would throw a bearing out. So its most likly the wheel bearing and you can just take it to a local automotive shop.
Aug 12, 2008 | 1991 Toyota Previa
Huffy So Sweet Children's Bicycle Logo
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
