Question about Mackie ProFX8 / TH-15A PA Package
Blown amp in the TH-15A . Is there a replacement amp assembly I can buy and how much
  • 4,234 Answers
Yes, the amp section can be replaced. It won't be cheap however. Your best bet is to contact Mackie directly. Do a web search for Mackie Parts and contact the service center. Thay will either take the order directly or refer you to a local supplier based upon your location. They have always been extremely helpful when I used them in the past.
Dan
Posted on Mar 13, 2011
No power in Mackie TH-15A
i) I assume the fuse you mentioned was in the mains plug - did you also check the fuse in the TH15A mains input socket? This is accessed by pulling out the tab in the bottom section of the socket (below the centre pin). This is a 3.15Amp antisurge fuse, 20mm type.
ii) If this fuse has blown, then replace it & all may be well ...... but if it blows again, then move to step iii).
iii) With mains disconnected, remove rear panel (outer screws) & check the power supply PCB for damaged components, especially R111 & R112 (100ohms). If the latter are burnt or open circuited, then the amplifier module may have blown.
regards, Dave
Aug 20, 2014 | Mackie TH-15A Active DJ Powered THUMP...
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
No sound out of my mack th-15a
As Tom Jones sang 'It's not unusual....' The amp has probably gone and you need to get it fixed. These are not the most reliable and I would suggest getting something better from another manufacturer if you can afford it, perhaps a local shop would do you a trade in if they can fix it?
Nov 11, 2013 | Mackie TH-15A Active DJ Powered THUMP...
Mackie Thump TH-15A speaker amplifier module
Jose Miguel Carcamo Cruces do you have pictures of these j112 fet ? Thank you!
Oct 07, 2013 | Mackie TH-15A Active DJ Powered THUMP...
When i put the start the liht is on off on off
tda8950th damaged. (low frecuency smd amp), good look.
Jan 25, 2013 | Mackie TH-15A Active DJ Powered THUMP...
Th-15 power light comes on and goes off but there is no sound
short circuit in secundary of the power supply or power amps damaged.
Jan 07, 2012 | Mackie TH-15A Active DJ Powered THUMP...
Will an Eminence Beta 15A speaker (`5", 300w, 8 ohm) fit/work in the k3000fx? If so, will there be a trade-off or consequence of performance? I already own the Beta speaker, and have a chance to...
It ill probably work, however I have had to do body-and-fender work on a speaker cabinet where the new frame would not quite set in the existing hole in the mounting board. The Eminence speakers are supposed to be good... are you sure the Behringer amp is OK? The K1800FX uses a conventional linear amp... not sure about the K3000fx... The only possible problem I could see is that the original speaker (Bugera 15 inch)may have a different response and the tweeter may not match too well. You can probably adapt using th EQ should this be the case.
Sep 01, 2011 | Behringer Ultratone K3000FX Keyboard...
Hi, I need to know how do you replace the 1" compression driver in a mackie thump th-15 and where would i get one from ? cheers.
After removing the back cover disconnect the tweeter cable form the terminal. Then hold the tweeter magnet and turn it anti clock wise. The driver unit will unscrew and come of the horn assembly.
Keep the driver unit on a firm table and unscrew the four + screws. It has a sandwich assembly which will part into two if you put a sharp knife and twist. You will see the tweeter diaphragm which can be lifted up again by using a sharp knife. The replacement diaphragm is available from the below given address
http://reconekits.com/tapcothumpth-15ahorndiaphragmpn0013252-1.aspx
Jul 04, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Bought a used Mackie TH-15A. When powered up there is no sound...at all.
The internal amp is in need of repair. Are there any other symptoms or signs?
Feb 08, 2011 | Mackie TH-15A Active DJ Powered THUMP...
TH-15A won't make sound. Comes on, then flashing front light
This probably means there is a failure and the internal protection circuits have activated. It will probably have to go to a shop for repair.
Jan 03, 2011 | Mackie ProFX8 / TH-15A PA Package
Mackie ProFX8 / TH-15A PA Package Logo
376 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
