Question about Promise FastTrak TX4650 4 Port SAS RAID FTTX4650 (P03619) Storage Controller
I have an Intek DG45ID motherboard, installed a Fasttrak TX4650 RAID card in the PCI-X x1 slot. The motherboard does not get past the BIOS post in the boot process, just after showing the boot options a green line appears at the top of the screen and the PC freezes. Take out the card and the PC boots normally. Put in another RAID card and it boot fine, only this other RAID card does not allow for RAID 5, thus my option of buying the Fasttrak controller, which apparently does not work. Might there be any incompatibility issues? I have a Quad Core Q9650 processor, 8 GB RAM, and am running Windows 7 64 bit version. The motherboard is configured for RAID 0 for the 2 OS disks, for speed, and I want to have an extra 4 x 2 TB disks running RAID 5 for my data,
  • 55 Answers
It seems that the card might be faulty. If there were incompatibility problems, they would normally show up under the operating system (Windows, Linux, etc), not during the booting process.
From your description, I suspect that the card's BIOS is corrupt. Try getting a replacement under warranty and see if the new card works normally (it should).
Posted on Mar 13, 2011
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
I need a new netowork adapter in Gateway GT5674
All over the place. What you need is a PCI Ethernet Card,
Gateway Support > GT5674 Desktop PC > Main Support page,
http://support.gateway.com/us/en/s/PC/R/1015322R/1015322Rnv.shtml
In the list click on Components.
Scroll down to the bold black subheading - Motherboards
Click on the blue -
4006254R - ECS MCP61PM - GM AM2 mATX Motherboard
Main top view of your motherboard, and as you will see it in your computer.
View the long White PCI expansion slot. Indicated by the letter R.
Also view the two shorter white expansion slots, indicated by the letter Q.
These two are PCI -Express x1 expansion slots.
IF, the PCI slot is occupied, you can use a PCI-Express x1 slot, if available.
The long white PCI slot uses a PCI Ethernet Card.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=763637&CatId=1175
If it is PCI-Express x1 slot you have available, use an example like this, a PCI-Express x1 Ethernet Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2543350&CatId=2380
The long Black connector, above the shorter white PCI-Express x1 slots, is a PCI-Express x16 connector.
It is ONLY used for a graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 14, 2012 | Gateway GT5674 Desktop PC
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
Emachine t3626 internet port can it be replaced
Absolutely!
The Ethernet port on your eMachines is part of the motherboard.
It is attached directly to the motherboard.
The eMachines T3626 Desktop PC, is supposed to use an
ECS MCP61-P (AM2) motherboard. (Cannot verify)
(Elitegroup Computer Systems. (AM2) refers to the processor socket )
http://www.ebay.com/itm/MotherBoard-eMachines-T3626-T5062-T5234-W3622-/320528791641
(Also scroll down for a larger photo of the motherboard )
The Ethernet port is in the group signified by the letter A, on the left.
The group signified by the letter A, is in the I/O area.
Input/Output area. This is where Input, and Output devices are attached, TO the motherboard. (Using the motherboard's chipset)
Now look down the motherboard, to the two long white slots.
These are PCI slots. Signified by the letter I ( i )
If one of these slots is not being used, plug in an Ethernet Card, that is PCI.
If both of these PCI slots are being used, use the small white slot above them, signified by the letter H.
This is a PCI-Express x1 slot. If it is available, use it.
Use an Ethernet Card designed to fit, in a PCI-Express x1 slot.
Example;
PCI Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=771339&CatId=1175
PCI-Express x1 Ethernet Adapter Card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
[ Note*
The PCI-Express x16 slot that you have, (Orange in color, above the white PCI-Express x1 slot), is for a graphics card.
It is ONLY for a graphics card.
The PCI-Express x1 slot is NOT used for a graphics card ]
(If you would like the proper procedure for installing a Ethernet Adapter Card, in your eMachines T3626, also state in a Comment)
Regards,
joecoolvette
Dec 19, 2011 | E-Machines eMachines Desktop PC
Hello, I will try to explain my problem as clear, however, as short as I can. I am building a machine off the P55V Sli motherboard (1156). Case mounted the board proberly, S-ATA's had a few issues...
there must be a video card in the first pci x *usually running x16* and the 2nd usually runs at x4. the motherboard will not post at all if there is a card in the 2nd slot but not the first (hence the beeps) you can buy right angle adapters for sata connectors if that helps and makes sense?
Mar 26, 2011 | Evga P55V SLI Motherboard w/ SuperSpeed...
LAN is not recognizing Internet port
Then you have reinstall *********** boards drivers from its cd.
Oct 25, 2009 | Intel DG31PR Motherboard
PCI Express 2 have in this bord?
  • One PCI Express* x16 bus add-in card connector
  • Two PCI Express* x1 bus add-in card connectors
  • One PCI Conventional* bus add-in card connector
Oct 09, 2009 | Intel DG45ID Motherboard
Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
Feb 06, 2009 | ASUS Computers & Internet
Tv card & Capture that support intel motherboard dg31pr
The Intel DG31PR motherboard has one PCI-Express x16 slot & two PCI slots. The motherboard also has 1 PCI-Express x1 slot.
You can use any of these slots. I am guessing you are using the PCI-Express x16 as you're primary video display. If you're not using the PCI-Express x16 slot & using the onboard graphics you could use anyone of these PCI-Express x1 capture cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3493&name=PCI-Express-Video-Capture-Cards
For the PCI slot (Two whit in color). Any one of these.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1425&name=PCI-Video-Capture-Devices
Video capture devices include a learning curve. Do not expect to add one of these into you're system without reading the instructions. (I know little of this format). The PCI-E x1 will be faster than the PCI cards.
I hope you found this helpful!
Good Luck!
Mike
Jul 15, 2008 | Intel DG31PR Motherboard
Promise FastTrak TX4650 4 Port SAS RAID FTTX4650 (P03619) Storage Controller Logo
622 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
none
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
