Question about PNY GeForce 8400 GS, PCI Video Card
Since instslling 8400 gs graphics card click on windows shut down it does then it reboots like you pushed the restart botton any ideas
    Problem Solver:
  • 14 Answers
It sounds like your machine is suffering from what is known as a "Panic." Don't worry, it is no reason for you to panic. What seems to be happening is that when you select "Shut Down," Windows instructs the graphics card and the software that controls it (called a "driver") to shut itself down. In the event that the graphics card fails or the "drivers" that control it fail, Windows crashes and the only way it knows to deal with that is to restart the machine. It is coincidence that whatever is causing this crash is a result of the shutdown procedure.
Here are some steps you can take to fix it:
Update your graphics drivers: Windows XP
32bit: Windows Vista, Windows 7
64bit: Windows Vista, Windows 7
If you don't know 32bit or 64bit, you are probably using 32bit
If that doesn't fix it then it is likely a problem with the card itself.
  • Try removing and reinserting the card. Make sure that the connector is seated completely.
  • Make sure that there is little or no dust in the fan. Heat can cause many issued in computer components. Use a can of compressed air to clean it out.
  • If all else fails, try to return the graphics card to your retailer if it has been under 30-days and you have a receipt. You may also attempt to contact PNY and see if it is eligible for warranty replacement through them.
If you cannot get a replacement through your retailer or PNY, see if you have a friend or co-worker that can loan you a graphics card temporarily. We are going to confirm a hardware issue before I instruct you to commit to purchasing a new graphics card.
  • Remove your graphics card
  • Install the borrowed graphics card
  • Restart your computer and then replicate the cause for the problem (selecting "Shut Down")
  • If the symptom remains (it reboots instead of shutting down), then the graphics card hardware is not the problem.
  • If the symptom is resolved (the computer shuts down instead of restarting), then your graphics card is faulty and needs to be replaced.
Posted on Mar 13, 2011
Computer restarts logging in windows 7
There could be any number of problems causing a Reboot loop. But the obvious one is that your graphics card won't work with Windows 7. It is too old.
Apr 12, 2012 | PNY GeForce 8400 GS, PCI Video Card
Hi.... my graphics card is Geforce Nvidia GS 8400. I had been played FIFA 11 in win 7 wih this graphics card.....before 2 days. but now,when i open fifa11 it can't working properly........(THE PROBLEM...
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall thye graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or you might need to download one
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need or major geeks download this graphics driver this will depend on your operating system
http://download.cnet.com/%7Bvalue=http://www.download.com/windows-7-professional/3000-18513_4-10906772.html Windows 7 is more than what Vista should have been, it's where Microsoft needed to go. How much damage Vista did and whether Windows 7 is enough for people to finally abandon Windows XP are questions that nobody has the answers to right now.
Jun 11, 2011 | BFG Technologies NVIDIA GeForce 8400 GS, ...
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
Just installed two new monitors. Have ge force 8400 gs card. Windows 7. I can see both screens, but they are acting as two single screens. mouse won't move from screen to screen.
It sounds like you have the monitors setup as mirrored monitors instead of an extended desktop.
When in the display properties of windows click the monitor you want to have as the extended desktop and you should see a check box for extend monitor to this screen.
Jun 22, 2010 | HP nVidia GeForce 8400 GS, DH PCI Express...
I need help with a nividia 8400 gs
see that ur vga cable is inserted on a graphic card
and reset ur cmos
Jun 07, 2010 | HP GeForce 8400GS Graphics Card - nVIDIA...
Tried to install pci 8400 gs video card.
uninstall all Nvidia drivers, restart your computer, reinstall the drivers. I have also ran into issues with these card before where you have to change the resolution by right clicking the desktop and selct properties. Other times you have to use the nvidia software for this type of change.
Feb 20, 2010 | HP nVidia GeForce 8400 GS, DH PCI Express...
I have a geforce 8400 gs pci interface. the card work ok but when i shut down my pc,it restarts it instead of shuting it down. whats the problem?
Hello gabini248,
Disabling "restart on system failure" may fix the problem: Right-click on My Computer, click Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” uncheck the box at “Automatically restart.” You may have to restart your PC for the effects to take place.
Jul 09, 2009 | HP nVidia GeForce 8400 GS, DH PCI Express...
Some games, like Hitman stop running under nvidia 8400 gs
Update/ reinstall the driver software. but it looks like you need a new graphics card
May 04, 2009 | HP nVidia GeForce 8400 GS, DH PCI Express...
Blank Monitor
I have the same system and card. The problem is the system is trying to run two monitors at once. Use Windows safe mode (F8 during boot) to uninstall any Pny drivers you may have put on. Reboot. Install the pny drivers again. Before rebooting, use the device manager to look at the display drivers. There should be two, an Intel one, and the pny Nvidia one. Disable the intel driver and reboot. Worked for me. Youmay also want to upgrade the power supply. The 3000 has a 225W and the 8400 card wants at least 300W.
Mar 28, 2009 | Computers & Internet
PNY GeForce 8400 GS,  PCI Video Card Logo
239 people viewed this question
Top PNY Computers & Internet Experts
David
David
marley mcelhinney
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
