Question about Zanussi 24 in. DE6744 Free-Standing Dishwasher
We have a zanussi dishwasher DE 6744 WHEN WE SWITCH ON THE TOP 2 LIGHTS KEEP FLASHING GREEN are we able to cure this please
3 Suggested Answers
  • 18 Answers
SOURCE: the power is on the cycle light is on but on the
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Posted on Aug 03, 2010
  • 18 Answers
SOURCE: where is the drain pump located on zanussi
The Drain pump can be got to by removing the circular filter at the bottom of your machine and all the screws that hold the plastics in including the round retaining plastic clip, only then will you see your drain pump prepellors, but if you want to remove the Drain Pump then this can be done from the rear of the machine you might have to remove the macine outside for this as you need to turn it on its side, from the back of the machine remove the two screws holding the big electronic motor this is plugged into electric sockets remove them also there is a rubber bung that holds this in place once unscrewed the motor needs a bit of a jig and it should slot out through the back of the machine. If you are thing of changing this it costs about £120 I got rid of the machine myself.
Posted on Aug 04, 2010
My Zanussi DE 4544s dishwasher has this fault, when you put any cycle on it reverts to the flashing green lights......any help would be much appreciated.
You need to go on line to the Zanussi web site and request the error codes for this machine. Once you know what the problem is you can pose a question!
Dec 31, 2012 | Dishwashers
My Zanussi aquapulse de 6654 will not start. Only the on/off switch light lights.
Hi, I have a zanussi de6965 had the same problem the only indicator light that works is the on-off button.I had a problem some years ago with my machine would not work and showed L3 as the fault as I remember. I was advised to switch off all power isolate from the wall is best(pull the plug out of the socket) I removed the front casing held along the top and down the inside by a number of small screws. You need to leave the two bottom screws in(one each side) Wiggle free the top half of the display panel to acess the box holding the PCB board.it's very fiddly you will need a sheet of paper and a pen to make a noet of the connecting sequence of the wires ( Mark the blocks of wires with numbers... when replacing everthing this should eliminate any problems) Remove the PCB board from its casing and turn over to expose the back. At the bottom left hand side I discovered two dry joints, I needed a magnifing glass to check all the joints just incase. The faulty joints were a little discoloured blackened slightly. Solution...I cleaned, fluxed and re-soldered the joints. When re-assembled all the parts. It will help when dismantling to keep a note of the number and size of the screws and where they were removed from.
My dishwasher is now working again. hope this helps.
Sep 23, 2011 | Zanussi 24 in. DE6965 Built-in Dishwasher
My Zanussi Induction cooker model ZKT 621LX is not working? When I try to switch it on, the display for all 4 cooking zones shows L and after a few seconds, it just shuts off? What could be the problem?
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
Apr 19, 2011 | Zanussi 23 in. ZKT641H Electric Cooktop
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
Where is the drain pump located on zanussi dishwasher model DE 6744 S ?
Sep 11, 2009 | Zanussi 24 in. DE6744S Free-standing...
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Open Questions:
Zanussi 24 in. DE6744 Free-Standing Dishwasher Logo
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
